Question about Yard Man Garden
1 mower will not start,no spark. The other will run for aprox. 2 seconds and die immediately!
    President:
  • 2,702 Answers
The mower that runs has a blocked jet in the carb strip carb and clean out also check fule filter and fule flow
Posted on Aug 07, 2010
Engine starts easy and immediately dies. Fuel supply is ok. Seems to be ignition/ interlock issue but i need some guidance.
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 30, 2015 | Garden
Kohler engine troubleshooting
Sounds like you got some dirt or rust in gas tank
try emptying the tank and cleaning it out. also check you bottom of you gas can too it could be souse of dirt in you tank.
Just remember to put fresh clean gas in mower gas tank after you clean it.
Aug 18, 2014 | Toro Garden
Honda mower hrr 216 pda starts up fine, runs about 2 minutes and dies out. I remove the carburator, took it apart and cleaned it, cleaned out gas tank and replaced with new gas, new air filter and spark...
Hello Frank,
I would purchase a compression tester from your local parts store. Check compression when unit is cold, then run unit until it dies. When it dies, immediately check compression again. If reading are close to the same your problem is probably not internal. If you loose a lot of compression once unit is warm and dies, its probably internal and will need to be torn down.(compression should be at least 60 psi if not more) If readings are the same, I would purchase a spark tester and check before and after again to see if your loosing spark once unit is warm. If compression and spark are both good before and after, problem is most likely carburation. Hope this helps. Good luck and happy wrenching!
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Sep 26, 2013 | Honda Garden
I have the 6.5 hp self propelled model, It starts fine and runs strong for aprox 5 min then dies, seems to die when it gets hot possibly, the die time is always the same aprox 5 min. Once it dies it will...
I don;t know what engine is on your mower but if it has the self contained electronic ignition coil I have seen happen on several engines. It would run good for several min. then the spark just stops . And it will not spark again until it sets and cools . Just make sure it is the ignition that is not working.
Sep 15, 2010 | Toro Lawn Mower With Toro Power Tools
My 98 explorer turns over but will not start. The fuel pump kicks on for half a second, then immediately shuts off. Does anyone know how to go about fixing this?
your truck has two sensors that are in control.There is a camshaft sensor that controls when the fuel injectors open according to camshaft position.If this one is bad the fuel injectors wont open and the engine wont get any fuel.It also has a crankshaft sensor that is in control of allowing spark to the propor spark plug at the right time.If this sensor is bad you will not have any spark to any of the spark plugs.The fuel pump will only run for 2 to 3 seconds unless the motor starts,it is designed that way and it primes the fuel system and brings it up to pressure.(aprox 40 psi )
Jan 09, 2010 | 1999 Ford Explorer
Engine starts dies down immediately.fuel is ok spark plug ok
Most likely the carburetor is not ok. An engine does not just DIE. If you press the prime bulb, does fuel squirt in carb. If it starts the runs for about 3-5 seconds then dies, there is most likely a float or needle shut off problem. Or it could be as simple as a clogged carburetor. It only takes one tiny peice to clog one. Take the carb off and make sure all jets( small holes in carb) are clean. Mike. Rate 100% please.
Jul 04, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
My mower starts and runs great when cold but dies when hot. It will restart but won't stay running until it cools off again.
How old is your mower ? Sounds like points and condensor if older model ,or ignition module if its newer , points tend to stick together when they get old causing no spark at plug when they cool they come appart allowing it to spark again , module is sort of the same except you have no way of replacing points you have to replace module .
May 11, 2009 | Garden
Garden Logo
95 people viewed this question
Top Yard Man Garden Experts
Phil Walker
Phil Walker
Jim Parker
Jim Parker
john h
Are you a Yard Man Garden Expert? Answer questions, earn points and help others
