Question about HP dvd1170e DVD-RAM Burner
Two things...when burning to DVD, burn process would fail and comment says, "calibration area full." Another concern is that it took a brand of DVD discs that I have been using for months, and is now burning at 8x when it is usually 16x. Thank you in advance for your help! Bryan
  • 212 Answers
Maybe its about the type of your dvds.use from high speed DVDs forburning.try to updat burning software too
Posted on Aug 11, 2010
I keep having failed burn sessions it says "Power Calibration error" what and how can I fix that
Their could be several possible reasons and solutions for the above error, basically what is happening is for some reason the CD/DVD burning software is unable to determine the Optimum Power Calibration rate (a small pre-burn test to determine optimal laser power for writing), resulting a disk burn failure. There is no easy way to pinpoint the exact reason, so try all the possible fixes from top to bottom (easy to hard) and see what works:
Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
Try burning at lower speeds (Highly effective).
If this fails try a different burning software
Aug 20, 2010 | Sony AD-7191A DVD±RW Dual Layer Burner
I had Sony dvd rw AW-G170A. It can read cds and dvds sucessfully. When i burn cd it works fine and burnt successfully. But when i burnt dvd it shows following error.power calibration error writing short...
you might want to try and update the firmware on the DVD burner, find out with the vendor if there is a fw version and how to do it, if not I would suggest hiring a professional.
Dec 17, 2017 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Macbook pro cannot burn DVD
you need a new dvd burning drive sorry
Mar 17, 2010 | Apple MacBook Pro Laptop Computer with...
When trying to burn a dvd half way thru process get burning failures any suggestions
Hello friend,
This can be caused by many things:
1. which software you use to burn dvds? i suggest Nero or CloneCD. 2. which DVD brand you use? you man use a good brand like Sony or Verbatim... 3. you may lower the burning speed by half the speed and see if this will happen again. 4. last thing, you should try different files, maybe the file that you are trying to burn is corrupted.
Best Regards,
Oct 30, 2009 | Mad Dog Multimedia USB 2.0 External Drive...
Tried to burn a DVD using Power Cinema by going Create DVD, Author & Burn etc. Get to the end for the buring process and got a error code: FF037303. What does that mean?-
means you have a faulty or failed DVD burner (error is Power Calibration Error, returned through the ATAPI driver). Test with different /branded/ blank media, if none work then replace the drive.If you find one that works, stock up.
Jul 16, 2009 | JVC Everio GZ-MG130 Camcorder
What BRANDS are compatable w/ HL-DT-ST DVD+-RW GSA-T21N? I have no problem burning regular DVD or CDs but can't get a complete burn (second layer) on DL. I'm currently using (failing) MEMOREX DVD+R DL. ...
My friend as the same burner on is dell laptop and he just burned 2 xbox 360 games on TDK DVD+R DL disks and it worked good but it took about 3 mins to finalize the disk so let your program finish
Mar 10, 2009 | Dell Computers & Internet
Power Calibration Area Is Full
it could be because you have far too many usb connected devices sucking the power from your system try removing a few usb connect devices and try again or buy a bigger power supply unit i reccommend at least 650 - 700 watt
Sep 26, 2008 | Dell Dimension C521 PC Desktop
Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty)
i had the same problem, first when i burn movies i was using fujilim dvd+r after 10 movies burned i use maxell dvd-r i burn just 3 movies then i had a error (Error Code at 786 (16)- Code 037303 (Medium Error, Power Calibration Fail (Cd Burner is Dirty) after doing a lot of things to fixed and research thounsands of webpages one told me to use a diferent dvd then i buy sony dvd+r and now everything work perfect, maybe it helps, write me if you need help.
weddie2006@univision.com
Jun 20, 2008 | Toshiba Computers & Internet
Problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Jun 13, 2007 | HP DVD940e Burner
HP dvd1170e DVD-RAM Burner Logo
129 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
