Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I need wiring diagram for ignition switch for 1997 chevrolet tahoe
    New Friend:
  • 103 Answers
Red and red/white is 12 volts constant
pink is ignition
white is ignition 2
orange is heat/ac
brown is accessory
Posted on Aug 14, 2010
  • gunman_7 Aug 30, 2010
    autopagetech -
    When you say the white wire is "ignition 2" does that mean it only has power in the "run" and "start" positions? What positions does this wire have power????????????
  • Jason Ewing Sep 09, 2010
    That is correct. That wire needs to see ignition through the cranking cycle, or you will have transmission shifting issues.
    New Friend:
The white wire will only have voltage in the Off (bulb test), Run, and Start positons. It will not have voltage in the Lock or Accessorie Postion. When this wire's contact opens you will have no Tachometer, Speedomete, or Gear shift indicator. Also the Check Engine light will be on and Transmission will be usually stuck in 2nd gear (called limp mode). I installed an aftermarket replacement switch and it last 92 days. I am going back with the OEM replacement and troubleshooting connections, Grounds, and Shift solenoids, Ect
Posted on Jan 15, 2014
Vacuum system diagram
If you look on the radiator support you will find a diagram of the vacuum system.
Apr 23, 2016 | 1995-1997 Chevy Tahoe Ignition Starter...
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
Need the speaker diagram wiring for a 97 chevy tahoe
1997 Chevrolet Tahoe Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size:
6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Rear Doors
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 01, 2018 | Car Audio & Video
I have a 1997 chevy tahoe. 5.7 liter motor. it was idling yesterday and just died. i have no spark. i have replaced everything with the ignition system except for wires and spark plugs. i have done the...
https://s26.postimg.org/j6u1vxn61/ignition.jpg
Click on the link.
I don't know what testing you've done? How long since a tune-up? Any applicable trouble codes? To check codes yourself, at the least, you need an obd2 code reader.
In the diagram, see the pink wire at ignition coil, that is primary voltage to coil, with key on, use a test lite and see if there is voltage? If no voltage, that circuit is fuse protected, I believe ecm 1 fuse, under hood fuse block. You need to do some testing and tell us what you find?
Sep 23, 2017 | 1997 Chevrolet Tahoe
1997 chevy tahoe pwoer lock inop. need wire
mite want to ck wires that go between door & door jam,,mite be broken wire?? just a thought,,
Jan 27, 2010 | Chevrolet Tahoe Cars & Trucks
1997 chevrolet tahoe radio stays on when ignition is off.
Review the wire connections; maybe this guide Radio Install Tahoe can help you.
Good luck.
Nov 03, 2009 | 1997 Chevrolet Tahoe
1997 chev tahoe 5.7 4x4.no ignition or fuel pressure.Flashed new reman ecm but wont work.
sounds like the anti theft system? make sure you get it checked these had problems with broken wires at the igntion switch in the sterring coulmn
Aug 31, 2009 | 1997 Chevrolet Tahoe
Need wiring diagram for 1995 chevy 1500 silverado 305.
need a wiring schematic for a 90 s-10 blazer cut the wires to dist now cant find leads
Aug 12, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
3,793 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Marvin
Marvin
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
