Question about Dryers
I am working on dexter dryer model#DFH6H and some one has been in their before me and . the timer has letters a,b,c,d, and what ever were do the wires go. dose a on the timer go to a on cool down timer and were dose the rest go
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Posted on Feb 11, 2009
localwonder
  • 6784 Answers
SOURCE: dryer is not heating. the dryer timer goes all
HI, The timer control module is the culprit. This device controls the heating functions of your unit. You have indicated that the timer will not stop the unit, and it continues to run after the cycles intended stopping point. This will confirm that the timer is damaged, and it should be replaced asap, if possible.
NOTE:-( Just to be safe, check the thermal fuse as well. This is a emergency cut-off fuse that will blow if the element overheats your unit. it is located on the blower housing, or vent duct inside the unit. Test the fuse for continuity. If it is ok, replace the timer).
Posted on Oct 16, 2009
The dryer in the picture isn't mine I'll upload picture later if I can timer has abc but it's lettered back to front ie 1-5 an there is nine pin connectors for timer then other wires for front panel did...
Email ernesto cuadra Fixya with a request for a schematic. He has one for a similar model. His email address is: ercupa@netscape.net
And, this information was found here:
Indesit tumble dryer
Hope that helps.
Oct 19, 2014 | Dryers
Need to replace my dryer timer M460-G
The problem is that the new M460-G timer does not have the same terminal letters as the old one (because there seem to be a variety of sub-models under the M460-G name providing varying options such as an "air dry" function). However, I've at least been able to provide the basic timed heat function using a different M460-G on my old Frigidaire Crown Gas Dryer M/N FDGB23RGS2 . To do this, figure out the terminal functions by rotating the M460-G switch and measure with ohm meter and also inspect wiring diagram (mine was at appliance pros dot com).
On Frigidaire Crown FBGB23RGS2 Gas Dryer:
The original M460-G is wired:
Terminal / Function / Color
A / Gas / Org
B / Line voltage / Red
C / Motor / Wh
Timer wired between TM and C
AD / Auto Dry / Pink
TD / Start Switch and Motor / Tan
On other M460-G Gas Dryer timer (from mystery Dryer), I wired it to into my Crown dryer as follows:
Terminal / Function / Crown Dryer Wire color
BU / Line Voltage / Red
BK / Motor / Wh
R / Gas / Org
V / ? / No Connection
Timer wired between TM and BK
WB / switched on while Motor & Gas / Tan
OR / ? / Pink (figured it was safe)6b1460b2-ed5e-4c5d-b06b-c654e59e7487.jpg
Nov 19, 2013 | Whirlpool Dryers
Magtag Neptune Dryer - when I press start it say Pause and stops instantaneously. Anyone have this problem and know the solution?
sounds like a bad control board it seems like you have a letter missing in your model number ...I looked up the part ouch ..http://www.repairclinic.com/vwo1/Maytag-Dryer-Model-MDE5500AYW-ID-563862-Circuit-Board-Timer-Parts?s=t-mde550ay-%3d%3dd563862b4a8c13
Aug 14, 2013 | Maytag Neptune MDE5500AY Electric Dryer
My dryer
Each wire has letters on it that match the letters on the timer. Look closely. x to x c to c etc.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 27, 2012 | GE DBXR463EDWW Electric Dryer
I wired my timer switch wrong i need to know which colors go where
The fuse is located on the heater housing we4x800 is the part number on most of these. Look closely at the wires on the timer each one has a letter on it the letters on the wire matches the terminal markings.
I have a frigidaire heavy duty dryer an when I was moving it I had to take the top part off with the knobs on it now I forgot which wire goes where can u help me?
Each wire has a number on it or letters that coincide with letters and numbers on the timer. Not all dryers are exactly the same. You must post a model number for a better answer. I have a late model service manual on my frigidaire dryer page HERE
Sep 26, 2012 | Dryers
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
I need wiring diagram for whrilpool ler5636kq1. timer
Good luck finding one. I look at the wires. They are marked with the same letters as that of each dryer terminal. I have a plain jane dryer manual from whirlpool but I doubt it will help much.
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
I have a sears model 110.86873100 clothes dryer with a defective timer mechanism. I received a replacement part from sears that is different from the original. It has 9 posts to attach wires too, and the...
If i may ask ,did you not find a wiring diagram in timer compartment or glued to inside of front or bottom panel ? Does the new an old timer have the posts marked by letters ?
Sep 24, 2008 | Dryers
I have a kenmore model 417.93042201 gas dryer that is about 5 years old. I had to replace the ignitor and in the process I removed the front of the cabinet. When I put it back together the dryer worked...
Look on the loose wire for a letter or number, it will be one or two inches from the female spade connector end. Then look on the timer and look for an empty terminal and see if the number or letter matches the one on the wire. If so, bingo! Attach the wire to the timer and see what happens. Also you could look on the wiring diagram for white wire and see where it positivley goes. Good luck. Remember to do all work with the unit unplugged!!
Aug 16, 2008 | Dryers
Dryers Logo
79 people viewed this question
Top Dryers Experts
Marvin
Marvin
