Question about Dometic Rooftop RV Air Conditioner
I have a air conditioner serial# 94522818 I want to know what capacity it is?
  • Dometic Master
  • 43,501 Answers
Need to know the model not the serial...but most of those units are 1 ton or 12000 BTU's
heatman101
Posted on Aug 08, 2010
What is BTU's of this model
Hello Friend, that's a great question!
I show that your post is listed under Frigidaire air conditioner (FAS1084M2A). I show that your air conditioner has a cooling capacity of 18,000 BTU's. If this is not your model number, please provide me the correct number. You can typically locate the serial tag (which lists your model number) behind the front grill by the air outlet or on the side of the cabinet. Other possible locations are on the front edge of the chassis base or behind the dial plate of the control panel. If you need further assistance, please feel free to reconnect.
Jul 11, 2014 | Frigidaire FAS184M2A Air Conditioner
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    I don't have a problem with my product...im trying to find out how many watts do my product use. Model #uamb-036jaz serial #6263f040410617
    Brand: RUUD Manufacturer: RHEEM Model Number: UAMB-036J* Condenser Type: air-cooled Condenser Coil Model Number: RCGA-36A2 System Configuration: split-system air conditioner Cooling Capacity: 34,200 BTUHs per hour Efficiency: 12 SEER
    10.5 EER Electrical Service: Single-phase Electrical Input: 3,272 watts per hour Voltage: 230 and 208
    Jul 01, 2011 | Ruud UAMB Air Conditioner
    Determining the age and size of a Trane evaporator Model # TXH054A4HPAF
    The serial number on that evaporator will have the date code in it, the model will tell the capacity (size). It looks like it is a 4 and a half ton or 54,000 BTU coil and has a TXV valve to meter the refrigerant.
    Jun 16, 2011 | Ruud UAKA037 Air Conditioner
    Please advise heating/cooling capacity for carrier quietline air conditioner vertical through wall model 25 years old model number unknown Thanks
    Hello rgar919,
    It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
    Thank you for choosing FixYa.
    Mar 06, 2011 | Heating & Cooling
    Can ypu please tell me the weight of the next chiller: MODEL: 50TJ-028-6B1YA SERIAL: 2806U15500 Or technical information Thanks
    DEAR SIR
    CARRIER STANDARD EFFICIENCY AIR-CONDITIONER,S DATA ARE GIVING BLOW:
    Specifications:
    ELECTRIC/ELECTRIC, HEATING & COOLING 50 SERIES - CONSTANT VOLUME, VERTICAL SUPPLY AND RETURN
    MODEL
    NUMBER
    NOM
    TONS
    NOM
    CFM
    NET
    COOLING
    (Btuh)
    NO.
    COOLING
    STAGES
    EER IPLV
    TOTAL
    kW
    HEATING CAPACITY (kW)
    (kW@ 460/3/60) WT
    (lbs)
    DIMENSIONS
    (in.)
    Length Width Height 50TJ028
    25
    7,200
    268,000
    9.3
    30.9
    32 / 55 / 80
    1,850
    86.125
    83.5
    47.25
    HOPE ANSWER THE QUESTION
    THANK YOU
    PLEASE VOTE1
    Sep 29, 2010 | Carrier 50TJ028 Rooftop Electric Cool Air...
    Can't find a manual for air conditioner
    BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
    To convert
    Multiply by
    To obtain
    kW
    1.341
    hp
    kW
    3,413
    Btu/hr
    hp
    2,545
    Btu/hr
    May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
    What is the cooling capacity of a 3 ton air conditioner
    Hi, the cooling capacity for 3 tons of cooling is 36,000 B.T.U.'s, For every ton of cooling, you have 12,000 B.T.U's of cooling. I hope this is what you needed to know.
    Good Luck,
    Shastalaker7
    Nov 04, 2009 | Carrier BCA101R Air Conditioner
    BTU's on Emerson Quiet Kool A/C
    AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
    May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
    How can we caculate the energy needed by an air conditioner?
    It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
    Example 35000 btus / 2500 watts = 14 EER
    If you know the capacity,btus and EER you can calculate the watts, capacity / EER
    Example 35000 btus / 14 EER = 2500 watts.
    EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
    80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
    May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
    Dometic Rooftop RV Air Conditioner Logo
    Top Dometic Heating & Cooling Experts
    Bill Long
    Tim Whalen
    Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
