Question about Dishwashers
White film especially on ziploc containers and utensils. Glasses come out spotted and clear glass dishes are streaked with a white film
  • 4,323 Answers
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Please post back if more information is required.
Daniel
Posted on Aug 08, 2010
Frigidaire d. w. grit and white film on glasses
Good Morning Friend,
I see that you are receiving grit and a white film on your glasses, in your Frigidaire dishwasher, model# FDB1050REC. Here are some common solutions that you can begin with.
-Check your water hardness. Hard water can cause lime deposit buildup on the interior of the dishwasher. Dishes and glasses may also get spots and film for a number of reasons. To remove buildup, spots and film, clean using the following instructions:
1. Load clean dishes and glasses in a normal manner. Do not load any metal utensils or silverware.
2. Do not add detergent.
3. Select the NORMAL WASH cycle. Close and latch door. Press START/CANCEL pad.
4. Allow your dishwasher to run until it starts the second water fill (approximately 10 minutes).
5. Unlatch and open the door, and pour 2 cups of white vinegar into the bottom of dishwasher.
6. Close and latch the door and allow the cycle to finish.
For extremely hard water, it may be necessary to install a water softener.
-Your water temperature may be low. Avoid extremely low or high temperatures.
-Avoid overloading and improper loading.
-Make sure you are using fresh detergent. Old detergent is ineffective.
-Make sure your rinse aid dispenser is filled.
-Check to see that the proper amount of detergent is being used for cycle selected.
-Your home water pressure may be too low-it should be 20 to 120 pounds per square inch (psi).
If none of these suggestions helps, I would suggest contacting either the manufacturer or a local authorized technician. Hope this helps.
-Best Regards-
WP
Feb 16, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
I am getting a white film on all my glasses and dishes, what am i doing wrong
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Feb 18, 2011 | Maytag Dishwasher
I have a new Ge profile modesl pdw7880 dishwasher. It does not clean the dishes. The glasses have a milky white film and spots. The black arm on the bottom has a white coated build up. Also there is a...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Feb 14, 2011 | GE 24 in. Profile PDW7800 Built-in...
There is a white film on the inside of the door plus glasses and utensils.This problem just started a few weeks ago.(the dishwasher is just about two years old). We use cascade and jet dry rinse agent,
Feb 09, 2011 | KitchenAid KUDS03FTBL Dishwasher
Cloudy film left on glasses and white residue on edgings on inside of door as well as white residue streaks on inside of door.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 23, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
White film over glasses . still water in bottom, not cleanign dishes.
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
Dec 18, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
White film on dishes and glasses
Dec 12, 2010 | Asko 1385 Dishwasher
Some of our dishes in the top and bottom rack are showing a white film, especially on plasticware and the outside of pots, pans, ceramic or regular glasses. Also some glasses on top rack , but not all,...
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
Nov 19, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
White film on dishes, glasses and silverware.
white film is actually from the calcium and magnesium found in hard water. your dishwasher is fine. its the water leaving the residue and spots. go to www.dishwasherfilter.com . they have a new product out exactly for this reason. very affordable and works amazing. you will love it.
Oct 06, 2009 | Dishwashers
Dishwashers Logo
283 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
