Question about Troy Garden
I have a Kohler SV590-0016 engine on my TroyBilt Riding Lawn Mower, Last year the wife mowed the grass and said that it started smoking. Then I tried to start it and it was blowing a wet fluid (oil, fuel mix, I think) out of the exhaust and the air cleaner housing. I drained the oil and oil filter to find very thin oil( with bad fuel smell) there was no evidence of metal shavings. The motor will start and run but dies out within about 5 seconds of starting. I have no idea where to begin with this problem. Rings, Head Gasket, Valves, any recommendations???
  • edmorrison40 Aug 07, 2010
    I took off the valve cover to check the timing and it appears that the valves are functioning correctly. I did notice that when I turn the engine over by hand, there is air coming out of the oil fill tube. I can clearly hear this hissing noise. . I am going to order a ring set and engine gasket set and hopefully get the wife off my back. LOL
  • edmorrison40 Aug 08, 2010
    jtmelcoff responded quickly and confirmed what I had suspected. really appreciate his assistance
    Guru:
  • 382 Answers
This definitely sounds like ring problems. I would not keep attempting to start mower until repairs have been made. of course if you do the rings, all the gaskets will need to be replaced as well. I doubt very much that there will be an issue with the valves, You can save your self alot of money if you make these repairs yourself. You can find everything you need right here, from manuals to parts.
Posted on Aug 07, 2010
  • Jtemelcoff Aug 07, 2010
    From what you are saying Im sure a new set of rings will fix your issue. good luck and happy mowing. Please dont forget to rate me.
    great and quick response. this second opinion confirms what I suspected. Great job.
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Kohler engine oil leak
Could have blown a seal however before checking for that I would check the drain plug and filter seating if you changed the filter. Make sure the drain plug is not cross threaded. You can run a little low but should never over fill. Hope this will help. Most of the time if over filled you will get some smoke as well.
Apr 25, 2014 | Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Bits of burnt stuff coming out of lawn mower
that was burnt carbon coming out and you did overwork that lawn mower not dangerouse but keep mowing long grass you will end up buy anew one soon
Dec 04, 2011 | Briggs & Stratton Briggs Stratton...
My wife was mowing the lawn and she hit a rock. Since than the lawn mower does not start and when it tries to start a little smoke will come out of the carburator area. The mower is a Sears eager 1...
Unless the blade is belt-driven, like on riding mowers, then the blade is attached directly to the engine crankshaft. Hitting a rock with a mower like this is a very common problem. You probably have a bent crankshaft. In most cases this can be repaired, but may not be worth it, considering the age of the mower. But you should call a local small engine/mower repair shop to ask for an estimate. The repair is not something you would be able to do yourself.
Apr 30, 2010 | Craftsman Garden
Lawn Mower smoking/mufler leaking oil
I have a yardman lawn mower that is two years old. It is now blowing oil out the exhaust and also blue smoke. Any idea what is wrong?
Jul 22, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
268 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
