Question about Coleman 10' X 10' Sundome Tent 9160K101
How many gallons of water does my Coleman Model 550 Sahara hold?
2 Suggested Answers
  • 4 Answers
SOURCE: im looking manual instructions for coleman Sahara tent
Go on youtube, you will find some excellent videos on how to....on a range of tents. I saw the coleman sahara tent on a video last year as I was considering buying one! Good luck!
Posted on Jun 03, 2009
In a 550 gallon barrel,how many gallon would 14 inches be ?
If the barrel is the same size from bottom to top, measure the height and divide 550 by that number. That'll give you the gallons per inch measurement. Take that number and multiply it by the 14 inches and you'll have the gallons contained at that level. This will only work if the barrel is the same diameter all the way up.
Feb 23, 2015 | Miscellaneous
How many gallons of water does a Kenmore series 80 model 110 extra capacity plus washing machine hold at max and at 1/2 max
The Series 80 washer has a max capacity of 20 gallons. At the lowest water level setting you would have between 14.5 and 15 gallons.
Dec 23, 2014 | Kenmore Washing Machines
I want a operators manual for a coleman powermate air compressor 20 gal tank
You should be able to download a manual from this site:
http://www.powermate.com/productmanuals.php?cat_id=1
The VLF1582019 is a 20 gallon model but you should confirm if this is the model number of your unit.
May 23, 2011 | Coleman Powermate 02 - Gallon Air...
Hello...I have a blackmax 60 gallon 6 hp compressor. Model # BL6006016. Twin cylinder, single stage. What kind of oil do I use ? Thank you!
Compressor oil is less demanding then cars, but car oil works fine. Normal 1W-40 would probably work the best.
You would hardly ever have to change it either, because there is no water, soot, or acids produced in a compressor, as there are with a car.
Feb 26, 2011 | Coleman Powermate 60 Gallon Air Compressor
How much water should be draining from Aprilaire 550?
thats too much.. and a waste of water... you should install a good ball valve water shutoff inline and let it trickle.. ideally, it should be net zero water wastage but there's always a bit.. my water take-off drain runs about once every 5hrs and its about a litre (its siphoning water out of the combustion chamber as well as the waste water from the humidifier.. (you can get those ball valves at homedepot for about 6bucks -- they're usually compression fittings as well)
Jan 11, 2010 | Aprilaire 550 Humidifier
DRHQ0421 HI PRESSURE SWITCH
Any pressure switch in the same range will work. R22 Rage about 350 cutout 275 cut in. R410A 550 cutout 450 cut in. Most F22 Head pressure ranges about 225 to 275 depending on the Ambiant temp. 410A about 350 to 425 psi. Keep in touch Johnstone supply handles Coleman evcon go to ther website or call there toll free number in your area and give them the model number and they can match it or cross it over to one that will work. Rus
Nov 25, 2009 | Heating & Cooling
Coleman powermate compressor doesnt hold air
CHECK YOUR TANK PRESSURE ADJUSTMENT KNOB ON TOP A LOT OF TIMES THERE NOT SET AT THE FACTORY.HOPE THIS HELP'S
May 22, 2009 | Coleman Powermate 11 Gallon Air Compressor
Im looking manual instructions for coleman Sahara tent
Apr 21, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Need replacement brushes for Coleman Air Comp L0552709
you can try at mastertoolrepair.com they have parts just have to see if your model is in there system
Jan 14, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman 10' X 10' Sundome Tent 9160K101 Logo
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
