Pride Jazzy 1103 Ultra Standard Power Chair  Logo
Posted on Aug 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pride victory and pride jazzy will not charge the batteries and when plugged in. The inhibit function seems to not be working either.
Anonymous
Level 3:
  • Master 692 Answers
  • Posted on Aug 17, 2010
Anonymous
Master
Level 3:
Answers
692
Questions
0
Helped
288820
Points
1801
Bad charger port on joystick only fix is to replace joystick or if it has a seperate charger port underneath the jostick that has to be replaced
I have a Pride Jazzy Elite. When I plug into the charger both the power light and the charge light turn green. Any help?
Question edited for clarity and to add the maker.
Question moved to the correct category.
Green lights normally mean your charger is working and the battery is fully charged Leasa.
There are three flavours of Jazzy Elite, this is the manual for one of them. not very helpful on the green lights though.
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_jazzy_elite_es_(elite_gen_2)_om.pdf
This is for the HD & 14 model. Same text
https://www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_elite_series_hd_and_14_om.pdf
Some videos.
https://www.google.com/search?q=pride+jazzy+elite+charging
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
1helpful
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
2answers
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Why when charging battery seems to drain instead
The 3rd wore of the charger plug tells the controller to shut off all power to the scooter while the charger is on. Check the plug for a broken wire
2helpful
All the lights are blinking on the speed display.. we've had the chair plugged into both the back of the chair and the armrest.. the chair still won't move.
The speed display will flash whenever you have the charger plugged in. Either in the back or in the joystick. Hopefully you didn't have them both plugged in at the same time. If after you unplug the charger you still get the flashing speed lights then you have an inhibit problem with the chair. The inhibit function will keep you from being able to drive the chair while charging. This repair is beyond anything you can do and must be referred to a Pride dealer or Repair service Hope this helps you
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
1helpful
My wheelchair shows full charge, 2 hours later, it is blinking and out of charge. This happens while I am at work and just setting at my desk. We had batteries tested and they are fine.
Pride has a problem with a battery cable that will draw down the batteries like you say just sitting there and I'm not sure if it is with the Jazzy 1113. I would contact Pride @ 1-800-800-8586 ask for Jazzy Tech support and explain your problem. They should be able to tell you more specifically what the problem could be. I still think the batteries can be a cause of your problem but the Jazzy folks can help Hope this helps
The battery on the Pride Jazzy 1103 will ot take a
Have the batteries load tested. If they have sat to to long then they will need to be replaced.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
