Question about Cameras
Hello! After switching on the camera, there is the red light but the lens doesn't open and in couple seconds the camera makes a noise and switches off by itself. What might the problem be?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it/or particles stuck within the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
We can try something to determine the cause. While your camera is switched off, put it in preview mode. This is the mode where you always view your photos. Swith the camera on. If you can view anything, it is definately an lens error.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 07, 2010
How do I fix a sticking lens?
hi, if when the camera is making a whirring noise when switched on the gears are either misaligned or damaged , with camera on slap the base of the camera using your palm, a couple of times should be enough, if this does not help , look closely at the lens if the lens is not straight , gently try a straighten the lens using your thumb and fore finger very gently , you will hear a light click , if this does not work , then the service center ,
Feb 01, 2016 | Sony Cyber-shot DSC-W50 Digital Camera
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
My Fuji s5800 camera has a 'zoom error'
try pressing the unzoom button and holding it for a couple of seconds until it fixes itself. and if it makes a noise, till it stops!
Apr 10, 2010 | Fuji Finepix S5800 Digital Camera
When I try to turn on camera it makes funny noises, the lens tries to come out and open but seems to be stuck, after a couple of attempts it stops and turns off, What can i do
My Olympus Camera when switched on the lens comes out and in 4-6 times then it goes off without the LCD screen showing anything, please help me repair it. my address misiani_bon@yahoo.com
Aug 24, 2009 | Olympus FE-280 Digital Camera
My Camcorder switches it'self off
you will need to send it back to sony explain the new problem arose after they fixed the first problem they will fix it free of charge even if there is no warrenty
Dec 06, 2008 | Sony Handycam DCR-DVD403 DVD Camcorder
Camera Lens Cover won't open
Since Sony will not sell parts you have 2 choices here, replace the camera or send it in to Sony for repair.
Apr 17, 2017 | Sony Handycam DCR-DVD403 DVD Camcorder
L2 Lens Error
I just gave it a very hard tap against my dinning table and it became alright!
Jul 07, 2008 | Nikon COOLPIX L2 Digital Camera
Error 2111 on camera VPC-S750
On my Casio Ddigital Camera the lens comes out when I press the open button but then it shows LENS ERROR and shuts down again.
Please advise what the problem could be.
Thank you.
Apr 03, 2008 | Cameras
"Lens cover not open" message
There is a switch sensor which will detect if the switch is open. Try switching rapidly a couple of times, as dust must be lodged.
Mar 25, 2008 | Sony DCR-HC21E Mini DV Digital Camcorder
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
