Question about Garden
Full of gas but mower suddenly stopped while I was mowing. What can I do?
    Brigadier General:
  • 4,088 Answers
Sudden stops are usually due to ignition failure unless the blade hit some obstruction which can cause the flywheel key to shear off and shift timing into no-run condition. With a sheared key, you can still get sparks, but they occur at the wrong time. Check for good spark at the plug and if ok, pour a small amount of fuel or starting fluid into the plug hole and try for start. It should pop several times. If nothing, remove the upper cover and check the keyway area--if the flywheel side and the crankshaft side don't line up, replace the sheared key. Hope this helps!
Posted on Aug 08, 2010
Just received my model 247.290001 mower was mowing when engine dies and will not turn over now
Did it stop suddenly? Or splutter and cough like an engine problem? If suddenly I'd suggest checking the seat switch wire hasn't become disconnected, if this doesn't solve it then check all the other safety switches.
Aug 14, 2015 | Sears Garden
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
Riding mower no longer moves.
If this is a hydrostatic transmission, one of 3 things:
1. Drive belt off pulleys (recommend replace belt if so)
2. Belt broken (obviously, replace)
3. Hydrostatic transmission failed (least likely, but this is an expensive repair shop issue if so)
This happened to my GT1554 two weeks ago - fortunately, replacing the belt resolve the problem.
Oct 19, 2012 | Cub Cadet Garden
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
Mower stopped suddenly electricity gets through to motor andblade rotates
were you mowing wet grass, if so you over loaded or over heated the mower. to high grass will do the same, Is this and electric mower or gas?
Sep 27, 2009 | Garden
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
