Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My WD 500gb passport hardrive was purchased this past January, about 7 months ago. It was working fine a few weeks ago, but one day I tried it and it would not come up. The computer recognized the hardrive saying the passport was found, but when I went into my computer, it could not be located. The lights turn on and look as if they are working, it just does not seem to spin up. I have about 15,000 pictures on this and I want it back! Please help!
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
I dropped my WD Passport on the floor and it got disconnected from the usb cord drive cable, when I plugged it all back in and plugged it on my pc it doesn't shop up anymore, how do I fix it?
Sadly you don't.
Dropping a hard drive and having it still work is something you should never expect.
You could pry the case open and put the drive it in an empty external drive case and see if it works, or try a new cable, but the most delicate part is the drive mechanism itself, and if anythings broken, that is most probably it.
You could probably get a replacement, maybe not WD, for around $60 and one I got on special $70 including postage from an online seller a few weeks ago had a 500GB WD drive in it.
Feb 06, 2011 | Western Digital WD Passport 250GB Portable...
I have a 250 GB WD Passport drive which 2.5 year old but still under warrnaty. few days back, it stopped detecting. When I tried to check with hard drive utilities, it passes quick test in no time but...
at this point performing recovery yourself may be risky, you may end up losing alot of data. A great software that I've used for few years now myself is FileScavenger.
You should try its demo version and see if its able to scan your drive and find your files, if it is, consider purchasing the software and recover your files, it will be much cheaper compared to the 300$ but the results can't be guaranteed at this point.
http://www.quetek.com/prod02.htm
whatever you do, don't write anything to the drive, only read from it. (you must recover to another hard drive and have enought space available)
Jan 22, 2011 | Western Digital WD Passport 250GB Portable...
I tried to format my 500gb WD passport essential with exfat using windows 7 for my mediastar pvr . Now neither pvr or windows 7 can see the harddrive
Windows 7 does _NOT_ support 'exfat' drives, as you have found out.
You can "format" the drive, to use 'FAT32' or 'NTFS' file-systems.
Dec 27, 2010 | Western Digital My Passport Essential...
I bought my boyfriend a WD 500gb passport hardrive in hope that he could transfer all his films on to it so we could watch them through his xbox 360. I asked around and I was told that the WD one would...
Does it work when plugged-in to any other PC/Mac? If not, it is DEFECTIVE. Return it, and get a replacement.
Does a different USB device (keyboard, mouse, memory-stick) work, when plugged into that USB port?
Dec 26, 2010 | Western Digital WD Passport 250GB Portable...
I am using the passport essential 500gb on my macbook pro. I dont use time machine...i just backup files manually. I tried to transfer an item to the passport and it told me that it couldnt be moved...
i almost have the same problem, i bought the
Western Digital My Passport Essential 500GBfrom a week ago and i left the drve connected to the laptop and copying data from an old WD drive and after couple of hours i found an error appearing.......then i clecked okay and restarted the laptop and from then my
Western Digital My Passport Essential 500GBdoesn't appear in my computer drive list nor in the device manager.
i just cut my precious data from the other drive.
PLZ help
Mar 29, 2010 | Western Digital My Passport Essential...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
WD Passport 500GB - My Computer Panel Freezes trying to recogniz
i know this wont help you, but i am having the exact same problem, so at least you not alone. if you have found anything out i would appreciate the feed back and visa versa if i figure it out.
Sep 29, 2009 | Western Digital Computers & Internet
WD Passport (External Hardrive) Not being read by computer at all
go to "system" in windows remove anything that pertains to this drive or, "usb" to this drive restart the computer and, the computer should find and, reinstall the software if not WD will have the software on their website
May 28, 2009 | Western Digital Passport WDXML800UE...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
73 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
