Question about Maytag MBB1956GES Bottom Freezer Refrigerator
Maytag refrigerator MBB1956 GES bottom freezer. Freezer works fine but frig is warm. Cleaned coils etc. The compressor comes on as usual. Any ideas....John
Krazytech
  • 725 Answers
SOURCE: Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Posted on Aug 18, 2007
  • 114 Answers
SOURCE: Maytag Frig. Model MSD2651HEQ not working
Your start relay for the compressor is probably the problem. If ordered, you will most likely receive the relay and overload protector. Replace them both.
Posted on Sep 28, 2007
  • 105 Answers
SOURCE: Refrigerator/freezer gets warm intermittently
sounds like your thermostat is faulty
the thermostat reads the temperature of the cabinet and controls the temperature
the 1 thing to check on the uprights is the evaporator is in the freezer and that makes the cool then there is a fan that blows the air around the fridge and freezer to freeze things
now there is a cycle that hapens to cycle usualy every 12 hours and that is the defrost cycle
this cycle turns off the compressor and fan turns on an defrost element on the evaporator and heats up the coils to get rid of the ice
the ice turns to water and runs through a drain to a evaporator tray and when the cycle is finished the fridge stars up again and goes into the cooling state again
when the thermostat decides that the fridge is cold enough it turns of the compressor and so on it goes through the cycles as required
if the drai is blocked or the defrost system is not working the evaporator will get choked with ice and the fan will not beable to let air through to cool things off
Posted on Jan 25, 2008
SOURCE: Freezer coils keep freezing up.
I had a similar problem with a Maytage Side-by-SIde Model MDZ2768GEW, (purchased in 2001). Defrost not working...poor cooling in both the freezer and fridge. We opened up the back of the Freezing side and the coils were iced. This Model is auto defrost so obviously something was not working. We called a Sears repair office and they sent a guy that told us we needed to defrost the unit. Well...I wasn't home and my father-in-law didn't question it - he defrosted it! I was busy at the time and didn't pursue it until the problem naturally resurfaced a month or so later. Not wanting to haggle with Sears over their Tech's lazy incompetence (or the $100 I was out), I decided to commence troubleshooting. I'm an ex Navy nuke electrician and electrical engineer so this didn't seem to be beyond my ability. Not having the Owners Manual, I internet searched until I found this site: www.servicematters.com/maytag_library/html/index.html. You can download your model's Service Manual and root around for other tech info their. I found the manual for mine and performed the troubleshooting for the Adaptive Defrost Control. Its fairly easy to do and you don't have to empty the entire fridge. You do have to empty the upper shelf in the fresh food (cooler) side to gain access to the controls. --This may not be in the exact order needed but you remove the light shield by pulling down on the back corners of the cover and sliding it forward (slotted attachment - no screws). Next Remove several screws holding the fascia / radiant shield on. Then remove screws that mount the control housing to top of fridge, etc. I also removed two screws that mount the ADC to the plastic housing to get access to the ADC. Basically, remove enough screws to lower the top assembly down to get to the ADC... --You may need to turn off the fridge now (or do it before you started the previous steps but the light helped me). If you are not using a Wattmeter, I don't think you need to pull the power cord. --The Service Manual next says to attach a Wattmeter to the fridge (and assumedly plug it back in). Most people don't have a Wattmeter...but what I had is a clamp-on ammeter...which you can get as part of "better" multi-meters for well under $100. An ammeter is good enough if you know how to multiply voltage and current to get VA (or approximately) Watts. Any idiot can do this...I think. P(Power) = V x I x pf. What you calculate with VxI is Apparent Power (VA). You convert to "real" power (Watts) by multiplying VA x pf. You generally have to guess at pf, but 0.8 for a motor/compressor is a good approximation and 1.0 for a heater or indandescent light bulb is roughly good. Enough electrical basics... --With Fridge plugged in, and being careful not to touch exposed connections, move the ADC control board so you can gain access to it (2 screws were removed previously to loosen it from the housing at top/back right of fresh food side). The ADC is a small printed ckt board about 3" x 3". --Use a small insulated jumper (or insulated alligator clip) and jumper Pins labeled "L1" and "Test". These are labeled on the PC board and were the two left-most pins, side by side, on my ADC. The Manual doesn't say whether to leave the jumper on or not. I tried both ways and I believe all you need to do is momentarily jumper the two pins (but my ADC wasn't working right, which I will get to later)...so I'm a bit unclear on this part. Also - DO NOT jumper between any other pins, or you may damage the ADC, if it's not toast already. The pins are close together so you need to take some care in doing this. --According to the Service Manual, you should read about 500-600 Watts of total power consumption if the unit is in Defrost mode. I found (referring to the electrical schematic), the main red power wire (ty-wrapped to a green/yellow wire that goes to the main lights). Power is red so it's process of elimination to find the "right" red wire. It's not that hard to figure out. I also confirmed this by playing with the door switch light and watching amps go up and down as I pressed & released the door switch. Ultimately, I measured about 2.2 Amps with the unit working normally (cooling) and 6 Amps in Defrost mode...and about 120 Vac supply. So...VoltsxAmps=VA, which equates to 720VA. I don't know what the power factor of the unit is...but with the compressor and freezer fan off, and only the defrost heater and lights on...the power factor would be close to 1.0. So my reading might have been a touch high but...what it did prove is that a) the heater works (I could feel heat off of it and I had the freezer panel removed and saw it melting ice), and b) the thermostat was working. --I also confirmed proper thermostat operation by measuring it "open" with an ohmmeter after the defrost cycle and measuring it "closed" once it cooled down enough (book says ~ 45F thermostat opens and ~15F it closes (to allow defrost when commanded by ADC). --What I found was that when I jumpered L1 and TEST, the Defrost didn't come on...until I manually turned the Freezer control off - and then back on again. Once I did this it started Defrosting (amps rose from about 2 to 6, compressor and freezer fan shut off and heater started heating. I repeated this twice after waiting for the unit to cool down after the defrost cycle. You can also just unplug the fridge to terminate the Defrost cycle and if the temp hasn't risen above the thermostat setpoint, you can immediately repeat jumper testing as necessary. --The defrost heater stayed on for about 5-8 minutes and after a total of 23 minutes the compressor/fan restarted - which matched what I read somewhere - though doesn't match the ADC Instruction Manual - which I show a website for further down. --So it appears the ADC is just not entering the Defrost cycle but does exit it properly. I believe that my problem is the ADC as I proved the heater works and the thermostat (as I mentioned earlier). Other than bad/intermittent open wiring, there's nothing else in the circuit and I believe I ruled out a bad connection by taking the thermostat connector apart several times and jostling wires up at the ADC to gain access. According to what I can find, the replacement ADC for my unit is Part No. 12002495. One should verify the P/N for their particular model. You can look at the Instruction Sheet here: www.servicematters.com/maytag_library/docs/16023486.pdf. It also has some info on how the ADC is supposed to work...NOTE: You should verify this P/N with someone, as I will before I order it. FYI...at Partselect.com, they show a replacement PN (their #) as PS2061226, for about $61. I've seen various prices on different sites and this was pretty reasonable. Lord knows what Maytag/Sears would charge. Maybe add a "1" to the front? ;) PartSelect also indicates different "Series" numbers for the same PS number for the ADC...not sure about which one I have so Buyer beware, make sure you resolve this before ordering -- I still have to. Anyway, hope this is helpful to someone out there in cyberspace. I will have to confirm my P/N and then buy the ADC. If anyone out there, esp pros, have any suggestions feel free to chime in. Except if you are the guy that told us to defrost our auto defrost fridge to "fix" the problem, for 100 smackers no less. You Sir, should be caned 100 times for being a slug. No economic stimulus for You!
Posted on Jun 04, 2009
  • 89 Answers
SOURCE: Refrigerate not working freezer not working
sounds like the relay is bad replace the relay this should take care of the problem it is located on the compressor
Posted on Jul 11, 2009
Refrigerator runs but freezer or fridge not cold. we cleaned coils with air compressor. Fans are working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 01, 2011 | Maytag MBB1956G Bottom Freezer...
Maytag model #PBF2255HES for several days I have heard a "clicking" every 5-10 min a clicking sound as if something was trying to start....now the frig and bottom freezer are not working. The...
heatman101
May 19, 2011 | Maytag 22.1 cu. ft. Bottom Freezer...
My refrigerator quit working and it appears the freezer quit as well. The light is still on in the frig. Model MBF 2556HEW S/N 10122300EL
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Apr 18, 2011 | Maytag MBF2556HEW / MBF2556HEB /...
Model MSD2756GEQ Maytag plus side is no longer cooling, the freezer is starting to defrost from the top, but bottom portion of the freezer seems to be still cold. the fan of some sort is still working, no...
Refrigerator
heatman101
Jan 29, 2011 | Maytag MSD2758G Side by Side Refrigerator
My Frig does not work, Yesterday the frig started to get warm until it is totally warm, I cleaned the coils, compressor runs, fan blows, fan on the coils blows. It seems like the compressor cylces...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | Electrolux Refrigerators
Frig warm, Freezer Cold
I have experienced this with other refrigerator freezers. The most likely cause is that the warming element in your automatic defrost system is no longer working. Ice is building up on the cooling coils and this prevents the refrigerator from getting cold. I have always called an appliance repairman to fix (~$150). If you're handy you can try yourself, but you still have to buy the part at retail. Good Luck
May 03, 2009 | Refrigerators
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Frig not working but freezer is
check and make sure you dont have frost on the back wall of your freezer on bottom and make sure fan is working
Dec 29, 2008 | Maytag MCD2257HES Side by Side...
Freezer cold but not frig. section
Switch off frig and let it completely defrost.
Jun 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Maytag MBB1956GES Bottom Freezer Refrigerator Logo
155 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
