Question about Sony KV-27S66 27" TV
Tv cut off and the standby/timer is the only thing blinky will not come back on
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
Sounds as if your timer is stuck on. Do you have the original remote to this television.? If so, does it also have a dvd or vcr recording device built in? If it does you need to go to the menu, if you can bring the menu up at all, and find the timer settings, and try to get the timer off. If that doesn't work, try leaving the tv unplugged for a while. Hope this helps you.
Posted on Aug 07, 2010
Tv will not stay on standby timer light flashing
On Sony the standby or red is for shutdown---
If you unplug the set and plug it back and turn it on and it repeats this look to see if the light is either constantly blinking or blinking a specific number of blinks---specific number would be an error code.
Apr 29, 2012 | Televison & Video
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
Sony sxrd --cuts off after a few seconds then cut itself back on.
Symptom shows lamp is weak and requires replacement.
Please buy Sony original lamp for TV safety and good picture result.
May 31, 2009 | Sony Televison & Video
Standby/timer light
check your menu settings to see if your off timer is activated or set.
Mar 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
TV doesn't come on but has blinking light on front
It means that the horizontal sweep dirived power supply did not start up. The standby supply started and then when the horizontal started to but was shut down because of a short, the main supply also shut down, Thats what the 5 blinks compared to the 6 blinks mean. Now what can yoiu do. It all depends on how much you know about solid state serviceing. iof you know how to unsolder and resolder, read a schematic diagram, know how to use a scope and /or multimeter, know how to test transistors , capacitors and resistors, then maybe you can troubleshoot this puppy. If you answered just a maybe to any of the above, call in a pro to assist you as these sets have no user serviceable parts inside them. Also lots o ,lots o high voltage inside of them, even when they are unplugged. Now if you do know anything about electronics, first thing I would do would be to check the horizontal output trasistor along with the flyback transformer.
Sep 12, 2006 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony KV-27S66 27" TV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
