Question about Whirlpool Dryers
Whirlpool Electric Dryer LER 7648PQO (hardly used) is not drying clothing. Clothes are being heated as they are warm when you open the door and feel them but after hours the clothing is still wet. I have cleared lint from the outlet to ensure it is not blocked. Does anyone hoave other ideas as to what to do?
  • 347 Answers
Still sounds like you have a restriction in the duct work going outside. check again with unit running for good airflow at outside vent. What you describe is what happens when you dont have good air circulation you end up with warm moist clothes,you need more than heat to dry clothes you need the air circulation to take away the moisture.....
Posted on Aug 08, 2010
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
I have a whirlpool dryer and the heating eleiment is getting hot but the dryer inside is barley warm
Inside of the dryer gets warmed up when the drum rotates as there is circulation of air. Hope your clothes are drying. If it takes long time then clean the screen filter as it gets clogged with the flint from clothes. As a matter of routine clean this filter every time you use it before starting the drying process.
Sep 16, 2010 | Whirlpool LER4634J Electric Dryer
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer turns off before cycle finishes
if unit has auto temp control,you may have a bad thermistor,,,,,make sure door is latching tightly,could be pushed open during cycle stopping it
Mar 03, 2010 | Whirlpool LER5636P Electric Dryer
My dryer won't heat
is it a condenser or vented tumble dryer
Jun 28, 2009 | Dryers
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
Relatively new dryer takes several cycles to dry normal loads
Check the lint trap all the way down to vent, then make sure that the vent is not crushed in anyway. Depending on the way the person cleaned it they could have actually caused more of a clog
Feb 11, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
