Question about Dremel Variable - Speed Multipro Rotary Tool 395
Unit wont run at all, yes I do have power, took apart and 1 of the brushes was stuck in slot and it looks like its been really hot.do I need to replace the switch assy. dremel 395 type 4,
  • 2,176 Answers
I would think that just the brushes, they should slide freely in the slot. check also the condition of the armature for arcing or raised commutator bars.
Posted on Aug 09, 2010
Belt issue
Check the switch to the brush bar it might not be in the right position it needs to be in to run or not run should be in a little slot that turns it on and off
Apr 18, 2014 | Hoover U5780-900 Windtunnel Cyclonic...
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
1981 evinrude 115HP outboard - The wire connecting
1) I cleaned the terminal ends and whether or not I mixed the wires up again, I really dont know but I managed to get the motor started.
2) I took the starter motor apart and cleaned the plates which make contact with the brushes, this made quite a difference to the working of the starter motor.
Feb 04, 2010 | Boating
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Brushes still wont turn
I had same problem and it was the turbine assembly. Part was only $28 but with labor it cost me $140 total. Plus it took over 5 weeks for my vacuum repair shop to get the part. In hindsight, I would have just spent another $100-$150 dollars and bought a new cleaner because now I'm having issues with the water tank leaking and I have to replace the valve assembly. Seems like it's always something.
Jul 14, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Stuck dvd in dvd player
This is what LG customer service will instruct you to do. I have a LG LDA-511:
1. Unplug your unit.
2. After unplugging, wait a few seconds then press and hold the power button (yes, while the unit is unplugged). This resets the unit.
3. Plug in your unit.
4. Press the eject button.
If the disc does not come out, then you need service from an authorized service representative.
Feb 21, 2008 | LG LDA511 DVD Player
Quick Flipoff
The air intake vents in the rear were clogged with dust. They needed to be brushed and vaccumed.
Oct 31, 2007 | Lasko 5132 Ceramic Compact Heater
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
270 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
