Question about Samsung Jet S8000 Cell Phone
My touch screen has failed how can i fix this?
  • 37 Answers
Try to fix it by having your cp being updated by the latest software. but if the problem persist, thus your hardware have failed. try to replace the touchscreen of your phone. hope this helps
Posted on Aug 07, 2010
How do we fix a repeating touch screen on a Janome 5700. The touch seems to be ok., but the display is not.
You might try recalibrating the screen. Short of that, could be a computer screen component is failing.
Nov 13, 2016 | Janome Sewing Machines
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
My lg screen won't touch... the lower bottom of my screen won't respond to touch
sir your lg cellphone the touching sencor has been failed.give to the lg cellphone servie center to change the new touching sencor device...........
Dec 26, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
My screen goes white, but will go back to normal after touching screen
Normally you shouldn't touch the display at all. By touch the screen you are directly touching the LCD module. Touching it maybe causing the screen to fail.
You will need to replace the LCD module to fix this issue.
Dec 15, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When I try to calibrate it keeps going on forever. The touch screen seems to off to the right a bit. Can this be fixed??
This issue can be fixed, sometimes a bit of pressure applied to the outer rim of the screen can fix the problem. More tecnical fixes are to open the ds and check the small ribbon cable at the left of the slot1 socket above the wireless connector, make sure the cable is in properly. Next if all that fails a new touch screen is probably needed.
Jan 09, 2010 | Nintendo DS Lite Console
I cannot get past the align screen page is there a way of bypassing it?
If it just keeps asking you to calibrate, then that means the touch screen is faulty.
Oct 24, 2009 | HP iPAQ RZ1710 Pocket PC
Screen touch is not functioning
A general fault is that the touch screen or its control devices has failed. In some cases, the ribbon cables or the pressure contacts between the screen and its controler are not making good contact.
If there is an electrical fault, the fix is to replace the touch screen, and its controler. In many of these types of phones everything is on the main circuit board. The general fix is to replace the main circuit board, or to replace the screen assembly.
The main cause of failure for these devices is dropping the phone, or getting it wet.
Jerry G.
Sep 27, 2008 | HTC Touch P3450 Smartphone
Samsung Jet S8000  Cell Phone Logo
131 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
