Question about Sony VAIO VGP-WKB1 Keyboard
My sony vaio laptop will load then goto a black screen with a cursor when there should be the log in screen. ive tried pressing shift 5 times and pressing f 8 what do i do
  • 244 Answers
You have an infection.
You need to load the explorer.exe
Do as follows:
When you are at the black screen with the cursor, press Ctr+Alt+Del, and start the Task Manager console.
From the File menu, select New Task (Run...)
Type explorer.exe and hit ENTER.
Your Desktop will appear again.
From there, try to clean your system from all infections.
When your system is clean and back to normal, look into a protection system called Pc Laptop Guard, so you wont have to go thru this or any other inconvenience again.
Don't forget to rate this answer if it helps.
Posted on Aug 07, 2010
I have a sony vaio mini laptop, after windows update it wouldn't boot up screen went black with flashing curser at left hand corner, but cannot type anything. tried restarting and even taking out...
you will need the restore cdrom's to fix this issue. sounds like you the wrong upates! you should only updates that come from the sony web site for your particular sony item.
refer to sony tech support.
Aug 22, 2011 | Sony Vaio P VGN-P530H Netbook
Hi, I have a problem with my laptop(2 yrs old). When I turn it on, it shows the microsoft loading screen with the logo and all, but after that the computer screen turns black-- not completely black, but a...
Sounds like a software error. When the screen has been blaxk for a minute or two try hitting control+alt+del and use the task manager to start the process explorer.exe if so then there is a registry or windows error and needs to be repaired.
Oct 23, 2010 | Sony VAIO VGN-C140G/B Notebook
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do...
Try these 1) Shut down the system 2) Remove the battery 3) Hold down the power button for say 2 minutes 4)Put the battery back 5) Boot the system
If you still hit the black screen with a cursor: 1) Wait for 2 mins at the black screen 2) Just type in your windows password (if you don't have one hit enter) and press enter 3) Wait for another 2-3 mins 4) Hit Alt Ctrl Delete and go to task manager (this time it should take you to the task manager) - fingers crossed LOL 5) Now do new task - explorer.exe
Hopefully you should be back in action.
Note, this is a work around and for a permanent fix either try and clean your system (check for viruses) or reinstall the system. Hope this helps.
Oct 07, 2010 | Sony Computers & Internet
Black screen with curser
It is what is called the "Black Screen of Death (BlSod)/(KSOD)" if you are using Vista or the later Windows 7. There are many causes for the BiSod/KSOD... some may say it is due to Micro**** updates and patches or as what Micro**** claims that is is due to malware infection, most likely something from the Daonol family of Trojans.
Google for it or I'll share you this site to give you some insights of the BiSod/KSOD.
here's one of many you could read:
http://www.pcworld.com/businesscenter/article/183502/three_tips_to_avoid_the_windows_black_screen_of_death.html
For a fix you may follow these steps:
After the black screen with cursor appears, press the shift key several times (5 to 10 times). A window should appear that reads “Go to the Ease of Access Center to disable the keyboard shortcut.” Click on that item, then follow these instructions:
  1. In the explorer window that appears, clear the address entry and type MSCONFIG then press enter. Run MSCONFIG.
  2. Uncheck the two items in selective startup and press apply, then restart the computer.
  3. The computer should start normally. Now click the Start button and type MSCONFIG again, then press enter. Uncheck Windows Event Log and Windows Event Collector, then restart the system.
This may or may not work on your state but your last resort is to extract your hard drive and back-up to another unit before re-installing your OS.
Hope this helps. Don't forget to rate.
Jan 06, 2010 | Sony VAIO PCG-K35 Notebook
Screen won't turn on
when u power up press F8 key then enter in enable vga mode then change screen resolution to 1024*768 then apply and ok thats it.
Jun 09, 2009 | Computers & Internet
Laptop screen goes crazy
Most of the time, Press F8 or F2 while booting up.
Mar 31, 2009 | Sony VAIO Notebook
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony Vaio wont start up Vista -hp
were you able to get on in last know if not then press f7 while in a restart then choose option to boot from your HDD
LET ME KNOW
make sure you have no cd in drive and nothing in usb ports
disk defrag is in accessories system tools
Feb 16, 2009 | Sony VAIO VGN-FS980 Notebook
When I restart my laptop, all i get is a black screen with my cursor...
Are you able to start the computer in safe mode?
Try starting the computer into safe mode by following the instructions found here.
If the computer loads in safe mode, then you can try disabling some startup programs by reading the instructions found here and restarting your computer. If this fails to fix it, you'll probably need to reinstall windows.
Steven
Sep 17, 2008 | Sony VAIO VGN-N130G/W Notebook
Sony VAIO VGP-WKB1 Keyboard Logo
153 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
