Question about LG 32LG30 32 in. LCD HDTV
The LG symbol only runs across the tv screen with cable on not with DVD
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
It is a screen saver usually on the tvs input. When you have the DVD players input on you should only see the DVD players default screen. s long as your DVD player is working and you can see your movie, everything is normal, some dvd players will let you put your own background picture on it.
Posted on Aug 07, 2010
  • LG Master
  • 8,457 Answers
Unplug,replug the cable box and the tv about an hour.The tv will reset itself,back to factory setting.The cable box should reboot itself and upgrade it softwares.The tv should work again.
What should my input screen on my lg tv be set on?
It should be set to where you have the input(ie...cable box, satelite, DVD etc) connected on the back or side of the TV
Jul 23, 2014 | LG 42LG50 42 in. LCD HDTV
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
When i try to play a Blue Ray DVD, the LG LCD tv gets a swath of bright green random pixels across the middle of the screen. The player is connected by an HDMI cable. I have replaced the cable twice,...
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
Jun 30, 2010 | LG 42LC2D 42 in. LCD HDTV
I have a lg 60in tv mw-60sz12 that has blue lines across the screen.i change the lamp and it still has the blue lines.
I have same Lg Mw60sz12 that had blue lines.. I found out it was the box that we plug all the different cables in for surround sound, dvd etc. The connection was loose and caused the blue lines.. as soon as I got a new box the lines went..
Feb 16, 2010 | LG RU-60SZ30 60" Rear Projection...
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Mar 12, 2009 | Panasonic PT-60LC14 60" Rear Projection...
LG 42LG5 hdmi not working
Have you tried another HDMI cable? The cable may be bad. However, if this is not the case and this is happening across mutliple devices(cable box, dvd player, etc) then you might have a bad HDMI input on your TV. Does this happen on all HDMI inputs on your TV? If you can safely rule out your other devices and the cable itself then you've got a main board problem and would need to get it replaced.
Feb 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
LG 32LG30 32 in. LCD HDTV Logo
205 people viewed this question
