Washer will not stop filling and overflows - Washing Machines
    President:
  • 2,702 Answers
The over fill velve is blocked of broken have a look in the back of the washer you should find a small pipe from the drum running up to a big round switch in the top of the washer ,, pull the pipe off the switch and
blow down it till its clear,,,then refit it,,if the velve is working this should stop the over filling,,,easy fix uh?
Posted on Aug 07, 2010
Fills Constantly
check the drain hose. Is it in the drain below the fill line of the washer?
In other words -- the drain line should be above the level of the washer lid top and in the line about 4-6 inches
Feb 20, 2014 | GE GTWN3000MWS Washer
Washer is overflowing
The water input on washers is controlled by the timer which actuates the solenoid valves for both hot and cold water, telling them when to fill and when to close. I would run the machine thru a fill cycle with the washer back off, and with a voltmeter, observe if the voltage ever cuts off as the timer runs. I Another variable is the water level control. So also determine if that is working since if it failed to open the 'fill' circuit at the proper volume, you might have this overflow problem.
Aug 15, 2011 | Maytag Washing Machines
Washing maching overflows
inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
May 05, 2010 | Fisher and Paykel WL26CW1 Top Load Washer
Myn washer always overflowes as it filling it wont
This is usually the pressure switch. Also you could check the water inlet valve if water is still flowing in the machine after it stops. There are free videos on testing these components at www.appliancehelponline.com/servicemanual.html
You can also punch in your model # for diagrams
Mar 18, 2010 | GE Washing Machines
Washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Jan 30, 2010 | GE Washing Machines
My washer didn't stop filling and overflowed. Is
un plug washer and turn hot and cold water on,if water come's in than you have a bad water inlet valve.if water doe's not come in than you nead to check the line from the water leavel switch to the outer tub.if line is conected on both end's and ther are no hole's in it,than you have a bad water level switch.
Nov 24, 2009 | Washing Machines
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer does not stop filling and it overflows!
check the pressure switch tube connectiong to the tub for a hole or crack first
Apr 23, 2008 | Maytag Performa LAT2500A
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
