Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Badger insinkerator 1(1/3 HP) is humming but not operating
  • Ace Hardware Master
  • 43,501 Answers
Here is a tip the I wrote that may help you to figure out what is going on withyour garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Posted on Sep 23, 2010
tbirdfan1
  • 3051 Answers
SOURCE: how do I remove unit from sink?
hi there first you need to get it cleaned out the best you can so you can see inside the disposer look at the verry middle of the disposal there you will see a bolt that needs to be removed it may be a special kind of bolt so just be prepared for that most hardware stores also sell a tool to help remove the bold and blade ...l after that bolt is removed you should be able to remove the blades than undo the pipes that are connected to it and any bolts and nuts ect ect. than pull out the unit if there is any silicone that seaoled the unit in it will be kind of hard but not impossiable to remove ok.
Posted on Feb 15, 2009
heatman101
  • 43501 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: I have a Badger InSinkErator, it suddenly just sto...
  • 130 Answers
SOURCE: Garbage disposle makes a humming noise when turned
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
Posted on Jun 06, 2010
  • 102 Answers
SOURCE: InSinkErator Badger 5, 1/2 HP Garbage Disposal: It hums but doesn't work. The wrench moves freely ...
If the blades move freely with the wrench and stick and motor hums then it sounds like it is time to replace the unit. Have you tried the reset switch? If it is humming than it is probably not tripped but worth a try. Hope this helps.
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Badger 1 1/3 hp insinkerator, all it does
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
heatman101
i
Posted on Sep 29, 2010
My Badger 5 is just humming and I smell a bad burning smell.
Either the Shredding Plate or the motor has burned out. In your case, it sounds like the latter. The motor is not repairable, you have to buy a new unit complete.
Insinkerator Garbage Disposal Hums But Doesn Work
Insinkerator Garbage Disposer BADGER 5Troubleshooting Repair Help
Badger 5 Garbage Disposal InSinkErator
Dec 09, 2017 | Electrical Supplies
Motor hums will not start until I spin shaft with t-handle allen wrench,then continues to run.
I have a badger 5 , 1/2 hp garbage disposal; won't run, just hums when I turn on switch.
Aug 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I have a Badger 1 1/3 hp insinkerator, all it does is a light hum. It had also tripped the electrical yesterday, it does not work.
heatman101
i
Jun 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
May 18, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
InSinkErator Badger 5, 1/2 HP Garbage Disposal: Just hums and won't run, even after assuring that ...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
May 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger 5, 1/2 Hp, won't operate, even after pressing the "red button." There is power to the unit: when we flip the wall switch the unit hums somewhat loudly. Ideas?
It's jammed. Turn the power off, get your hand in there, and twist the rotor back and forth until it unjams. Hitting the rotor with a big wooden spoon would work, too.
Oct 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Still doesn't run.
well, the impeller is slipping on the motor shaft, you need to remove the unit and see whats up
Aug 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
922 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
