Question about ViewSonic N2000 20 in. LCD HDTV
Fuzzy Display Screen works, however the screen is a little fuzzy. What should be causing this effect? Screen was fine with old computer. New computer does not work well. Images, icons, fonts are fuzzy and not very sharp in detail.
  • 3,037 Answers
Right click on the desktop, click on properties, click on the settings tab and then you should be able to change your resolution if it is a resolution problem.
I otherwise think that the cable may be bad and you may want to try a different cable.
You are not using a splitter correct?
Please keep me updated on this problem.
thanks
Posted on Apr 27, 2008
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • ViewSonic Master
  • 19,396 Answers
Try changing resolution from display properties window
  • ViewSonic Master
  • 13,433 Answers
Try to reset the device into factory defaults, you should be able to perform that from the menu. then set the native resolution and perform the auto adjustment.
  • Ekse Apr 27, 2008
    Im not sure is this correct but i beleave your native resolution is
    640 x 480 pixels
    you are probably useing a too big resolution and that is causeing the problem.
Half screen
Sounds like a faulty screen, has the laptop been dropped or physically damaged? can you only see half of the screen? if the other half is black and one half "fuzzy" it's most likely that the liquid crystal display has been cracked/broken. The only way to resolve this problem is usually by replacing the screen which in some cases can be as expensive as a new computer :(
Apr 28, 2013 | eMachines Computers & Internet
Fuzzy screen hp mini laptop
Try updating your graphics driver through Device Manager.
1. Right Click on "My Computer" on your desktop
2. Select "Properties"
3. Go to the "Hardware" Tab
4. Then select the "Device Manager" Button
5. Click on the tiny + next to display adapters
6. Right click on your display adapter and choose "update driver"
7. Follow the instructions and let it search for a better driver
If this doesn't work then you will need to bring it in to a computer shop to have the screen replaced. Get an estimate first before they do any work on it because it might not be cost effective to have it fixed. In which case you can hook it up to a monitor with a VGA cable to still use it, but it won't be portable anymore.
Good Luck!
May 14, 2012 | HP Mini 1010NR Notebook
May 14, 2012 | Computers & Internet
Ace 1 aspire computers works fine but the screen comes in fuzzy and unclear.
Bad connection from the motherboard to the screen, maybe a loose VGA cable
It could also be an overheated graphics chip, does the display appear to "shimmer" as well as being fuzzy?
Try cahnging the resolution and screen ratio, see if that helps first
Jan 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
Fuzzy Screen Display
this sounds to me that water has leaked into the screen
Apr 11, 2009 | Nintendo DS Lite
Font and screan to big and fuzzy
Right click on your desktop. Click on properties.
Click on Settings. Adjust the resolution based on the documentation for your screen.
Jun 27, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Fuzzy, unstable display
This sounds like a high-voltage power supply problem, which would need to be diagnosed by an experienced computer or electronics technician.
Check to see if there is a small focus knob on the back. If so try turning it back and forth three or four times to "clean" it....then adjust for correct focus.
Symptoms like this can also be caused by accumulated dust inside the monitor.
Jan 15, 2008 | Sony GDM-C520K (Dark Gray, Gray) 21" CRT...
Kogi Monitor with fuzzy text
Here is one small solution. goto start: -> control panel -> display click on the "appearance" tab. then click on "effects" check the box that says: Use the following method to smooth the edges of screen fonts (and make sure to choose "cleartype") You should notice the fonts are a little sharper as well as having a backdrop.
Mar 23, 2007 | Kogi L9CH 19" Flat Panel LCD Monitor
Fuzzy Display
check your sharpness control in the adjustment setup. If its set to max you might or sme sets have a tendancy to look grainy. Also check your source and be sure the signals strong. Such as just adding another tV to a cable line can cause weak signal. Ceck it with another set in its place. If thats the case simply add a small 20.00 cable amplifyer. Good Luck
Jul 27, 2006 | ViewSonic N2000 20 in. LCD HDTV
ViewSonic N2000 20 in. LCD HDTV Logo
160 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
