Question about HP DeskJet 930c InkJet Printer
Ink on the bottom of the printer ? - HP DeskJet 930c InkJet Printer
  • 48 Answers
Refill or non-hp ink cartridges have been known to leak ink into the printer.
Posted on Aug 31, 2010
Printer prints bottom half of page with less ink
Either your ink cartridge is low or your print head is going bad. Try printing in 'draft' mode.
Dec 13, 2012 | HP PSC 2410 Multifunction Ink Jet printer
Printer not printing black ink after replaced ink cartridge. 3802 error
DID you remove the small tape sealed on bottom of cartridge?
also check for dried old ink sploch in cartridge cradle bottom
right click printer use the printer utilities to clean print cartridges and align the cartridges nost printers have utilies or tools to assist
Jun 13, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Re Canon 2600 printer.I recently purchased a black Ink cartridge and replaced the old one. A week later the color cartridge also shows empty even though I hardly use color. Can I not print in greyscale...
Please follow the instructions below from Cannon support page...
Setting the Ink Cartridge When printing, you can specify which ink cartridge to use. This is convenient if one of the ink cartridges becomes empty, you can continue printing by specifying the ink cartridge that still has ink. Note:
  • When the following settings are configured, Black Only is disabled. The color ink cartridge is used to print.
  • A type of paper other than Plain Paper is selected for Media Type on the Main tab.
  • Borderless Printing is checked on the Page Setup tab.
  • Canon recommends that you use the ink cartridges installed in the printer and not remove them until the ink runs out.
You can set the Ink Cartridge Settings from the Maintenance tab in the printer driver.
To access the printer driver from the application software, click here.
To access the printer driver from the Printers folder, click here.
Application Software -
Note: Depending on the application software, command names or menu names may vary and there may be more steps. For details, refer to the user's manual of the application software.
  1. Select the command you perform printing on the application software in use. In general, select 'Print' on the File menu to open the Print dialog box.
  2. Select your printer model name and click 'Preferences' (or 'Properties'). The printer driver setup window appears.
  3. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  4. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  5. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  6. Click 'OK' on the Ink Cartridge Settings window.
  7. Click 'OK' or the applicable button to print.
Printers Folder -
For Windows 7
  • Click the 'Start' button from the bottom left of the Windows screen, and then click on 'Devices and Printers'.
  • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences' from the menu that appears.
For Windows Vista
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, click 'Printers' directly from the 'Control Panel'.
  • Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
  • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
  • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000
  • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
  • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  1. Click the Maintenance tab. (The Maintenance window opens.)
    Note: The layout varies depending on the printer and version of Windows you are using.
  2. On the Maintenance tab, click the 'Ink Cartridge Settings' icon.
  3. On the Ink Cartridge Settings window, check the 'Ink Cartridge' drop-down to see what it is it set to.
  4. To change Ink Cartridge to Black Only, click the 'Ink Cartridge' drop-down and select the option.
  5. Click 'OK' on the Ink Cartridge Settings window.
  6. On the Printing Preferences window, click 'Apply'.
Mar 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have an Epson stylus nx400 printer. I bought the ink refill kits that were recommended for it, but it's not listed on the instructions. I just want instructions on how to refill my cartridges.
Use syringre with small outlet. Fill from bottom side of ink tank. Better you don't refill ink tank. It will distort rubber seal at bottom side of ink tank. Then ink will leak. After refilling, you must reset ink counter. Do you have chip resetter?
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
Waste ink tank over flowing??
Hi, like every ink jet printer, there should be an ink pad(spunch) at the bottom of the printer to collect the waste. That spunch might be full of ink. You could locate it, remove and try to clean it under the water. See if it works
Apr 03, 2009 | Canon i860 InkJet Photo Printer
Flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Mar 10, 2009 | Epson Stylus Photo R1800 InkJet Printer
How to refil ink in hp 2120 cartidge
actually your printer cartridge was cloted or maybe airlocked.
You must use tissue paper and rub it on the nozzle side. Ink may flow out.
sukumar.t.k.
Jul 30, 2008 | HP Office Equipment & Supplies
Black ink not working
Before wasting a lot of time, the best way to trouble shoot ink problems is to try installing a new cartridge and see if it works. If it does, focus on the cleaning/diagnosing of the old cartridge and not the printer.
Generally, most newer printers when unable to print a particular color can be fixed by simply (1) switching out the ink cartridge with another cartridge, (2) cleaning the base of the cartridge and the corresponding copper contacts on the casing with rubbing alcohol or a damp paper towel and patting them dry, or (3) cleaning ink from the well below the cartridges (where the head parks when the printer is not in use.
That said, it does depend on the type of printer you're using. Some printers, like Cannon inkjet and bubblejet printers use an ink nozzle in the casing which was supposed to keep ink costs lower, but it had a tendency to cause clogs of ink in the printer. This is one reason most ink jet printers, like HP, have opted with installing all the necessary components in the cartridge itself.
If you have the other type of printer, where the ink cartridge has what looks like a hole on the bottom of the ink instead of a copper surface, focus on cleaning the bottom of the casing where the black ink is installed. You can do this with a cotton swab and some alcohol. Dip the swab in the alcohol and carefully move it in a circular pattern in the bottom center of the casing. This should hopefully clear the dried ink away.
Hopw this helps and remember to vote. :D
Jul 28, 2008 | Office Equipment & Supplies
Printer seems to be leaking ink?
take those out are uusing off brand ink
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Black ink leaking from bottom of printer!
There is a small hopper inside of the printer, called the cartridge holder, this is where the excess ink is wiped off of the cartridges, and is just left there. it is usually on the side where the cartridges stay when they are idle. The easiest thing to do, is take the cover of the printer off, and blot the ink out of the hopper, do not use any detergents, or liquid cleaners, as this will ruin the cleaner head for the cartridges.
Jan 18, 2008 | HP PhotoSmart 1315 InkJet Printer
HP DeskJet 930c InkJet Printer Logo
81 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
