Question about Bose 701 Main / Stereo Speaker
Purchased bose 701's a few years ago now not getting sound from right speaker. Left speaker with internal amp works, but now i'm finding that i'm not getting any bass boost when i hit the switch on back of speaker
  • 11 Answers
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
  • 4234 Answers
SOURCE: Do all speakers have fuses? I may have blown one of my Bose 151 outdoor speakers, but can't find a fuse inside.
Unfortunately many speakers do not have fuses. Most likely the voice coil has opened up inside the speaker itself. You can either get a replacement driver (speaker) or re-cone the one you have. In any case, the driver needs to be replaced.
You can verify this if you use an ohmmeter. With an 8 ohm impedence speaker, the reading should be about 6 ohms. If you read a higher number or infinity, the coil is bad.
Dan
Posted on Oct 08, 2008
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
gymhasafit
  • 31 Answers
SOURCE: how do I get sound from bose cinemate while watching Bluray with?
You are right I checked the Manual online and there is no Optical in. The other tech was right in suggesting that, Cause it would be the next best thing to HDMI. It only has 1 Analog Audio in, So what I would Recommend is Plugging in all of your Devices to your TV and then 1 Audio cable from your TV to The Bose input. Although this will NOT transfer Digital Audio to Analog Audio. This means if you are going in HDMI then the Audio would most likely NOT transfer to the Bose. In this case you would have to hook up a set of Audio cables (Red and White) From the Blu-Ray to the Bose along with the HDMI. This will leave you with only Audio from the Blu-ray through the Bose. To go a step further you can purchase an Audio Splitter (or Video) then plug your Devices into the Splitter and then 1 cable out to the Bose and just Switch the Input along with the TV. Good Luck!
Posted on Apr 29, 2009
  • 336 Answers
SOURCE: I have purchased a samsung 46 inch LED television.
You may have to go into the bose setup and select optical in for that particular input. Check your user manuel it should say in it.
Posted on Aug 16, 2009
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
Jul 29, 2010 | Bose Companion 3 Computer Speakers
Left speaker works but right speaker does not work gene.hall33@yahoo.com
Funny, this happened to me just 2 days ago, but I get no sound from the left speaker. Maybe they have all of them rigged to fail at a certain time.
Jul 08, 2010 | Bose Companion 2 Series II Multimedia...
Recently, I purchased a used set of Bose 901 VI speakers. They are crackling when base sounds play. What is the problem? Was I duped? Is it the speakers or the amp or the volume. Can I repair?
It is likely that the speakers were damaged by someone playing the system at way too high a level.
If the noise sounds like a scraping, then it is the speakers themselves.
If the noise sounds like a breaking sound then it is likely the amplifier.
Another possibility is that if you are not useing a Bose amplifier, then your amp may not be capable of properly powering the speakers.
Jan 18, 2010 | Bose 901 VI Main / Stereo Speaker
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
Sound but not audible coming from speakers.
If the problem does not depend from the source, then that sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
Mar 13, 2009 | Bose Companion 3 Computer Speakers
Front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Dec 23, 2008 | Bose Lifestyle 12 System
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
5.1 Home Theatre - PC
Its due to 2.1 channel sound input from your PC. Your Laptop supports only 2.1 channel sound so all the 5 speakers cant be played at a time! You need 5.1 channel input to work all 5 speakers
Dec 07, 2007 | Bose 701 Main / Stereo Speaker
Bose 701 Main / Stereo Speaker Logo
66 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
