Question about Optoma HD20 DLP Projector
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Posted on Dec 25, 2010
  • kaufmanek Dec 27, 2010
    Hi kgomer782: I solved HDMI signal issue. It was due to the 35ft cable plug male HDMI ending which indeed was not completely "seating" in the Optoma HD20 HDMI port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim female ending. This extension 3ft HDMI cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
  • akempwill Jan 11, 2011
    How did you discover that the seating issue was your problem? I am having the same problem with a 30 foot HDMI cable, and it seems fully seated to me.
Sound issues when connected to PS3 with HDMI
I don't think you can hook a PS3 to 350W projector. You are maxing out the PS3 output. Good luck with it
May 03, 2014 | Optoma PRO350W Projector
I can not get 7.1 HDMI audio output on my Gateway GM5664 running Windows 7.
While DVI and HDMI offer compatible video lines, the DVI connection offers support for two analog audio channels only and cannot transport data packets required for digital audio. You will not get anything beyond 2.1 audio across the dongle.
If you have a HDMI connector on your graphics board and your external hardware, try to use a proper HDMI cable.
Mar 14, 2014 | Gateway GM5664 Desktop PC
Hdmi port lost after lightning strike how to replace
Something for the Mythbusters if ONLY the hdmi connection fried... Knock on wood if the projector still works at all. Changing fuse could help?
Aug 14, 2013 | Optoma HD20 DLP Projector
Optoma HD20 DLP Projecto problem
this is not an hd20..... nor is it the right kind of capacitor that an hd20 needs...........
Aug 21, 2012 | Optoma HD20 DLP Projector
Optoma HD20 brightness changes periodically
I read the above and it ended up just being my HDMI cable contact being a little lose from me moving the unit around all the time. Just pushed it in and we're back in action!
Jun 11, 2012 | Optoma HD20 DLP Projector
Optoma PCB MAINBOARD MODULE FOR 8EG
My HD20 also broke after about 1000 hours. Their estimate is $703.00 to replace main board and lamp module. Image shuts off automatically after 3 mins of starting. Lamp fail led goes solid red.
Nov 10, 2011 | Optoma HD20 DLP Projector
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
Hi i want to connect a tv to my optoma hd 66 projector
hi,
You can't be able to connect a tv to your projector, because it doesn't have a monitor out.
There is only one way. If the source is a DVD player then connect the its HDMI output to the projector and the component video out to the tv. You can't be able to get video out from the composite video output of your DVD player, when you are using HDMI. When plug the HDMI it will switch off the composite video out. The component video out remain ON whether you connect HDMI or not.
ok
Mar 31, 2011 | Optoma HD72 Multimedia Projector
I just got a new Optoma HD20 and only after 1day of use it is not showing HDMI signal, although it is showing VGA signal. Why is this?
Hi miracles4all: I solved HDMI signal issue in my Optoma HD20. In my case it was the lack of contact between the HDMI cable plug male ending and the Optoma HD20 HDMI female port. My 35ft cable plug male HDMI ending was not completely "seating" in the Optoma HD20 HDMI female port. I solved the problem by purchasing a HDMI female to female coupler and adding a 3ft HDMI cable that had a slim male ending. This 3ft HDMI extension cable made better contact to the Optoma HDMI port and the projector was immediately able to detect HDMI signal. Hope this helps you... kaufmanekpr
Nov 05, 2010 | Optoma HD20 DLP Projector
Optoma HD20 DLP Projector Logo
1,305 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
