Question about GE WBB4500EWW Top Load Washer
I have a GE WBB4500E1WW When it goes in to the spin cycle it sounds like it is going to blow up real noise
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
Fix it Matt
  • 14 Answers
SOURCE: ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
  • 1738 Answers
SOURCE: ge # wbb4500e1ww stops during fill, wash,spin and
Check your hose end. On your hoses there are screens at the end that goes on the washer, and that screen could be plug enough to intermitent.
Posted on Dec 07, 2009
SOURCE: My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
Posted on Dec 19, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Washer WBB4500E1WW is deafening loud when it spins.
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 17, 2010
BELT BURNT FRAYED THEN BROKE, SOUNDED LIKE BEARING NOISE
It may be a garment stuck in between the inner drum and the outer shell
Aug 31, 2012 | GE WBVH6240F Front Load Washer
I have a WBB4500E1WW washer that started to make noise when in the wash cycle. Could a bearing be going out or what should we be looking for?
http://applianceassistant.com/repair/sounds/ddWasher_noises.php pa 1schmidt, without hearing the sound it is hard to say. Here (above) is a wonderful link for strange sounds made by washers and the parts to check for them. Wonderful site as well.
I would bet that something is stuck in the pump and needs to be removed, but it could be several other things.
Hope you find this link helpful; if you need any further help, dont hesitate to contact me.
thanks,
Mike
Jul 19, 2011 | GE WBB4500EWW Top Load Washer
My washer is making a horrible noise when it goes into the spin cycle. It sounds like it is about to explode.
The bearings on those washers go bad and the washer gets very loud during the spin cycle. It probably won't explode but for what it might cost to fix it you might want to blow it up yourself
Jul 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dec 19, 2009 | GE WBB4500EWW Top Load Washer
Ge # wbb4500e1ww stops during fill, wash,spin and rinse cycle intermitenly there is no regular pattern we can follow. We are lost as to what to do
Dec 07, 2009 | GE WBB4500EWW Top Load Washer
May 03, 2009 | GE Washing Machines
Ge profile prodigy make clunking before spin cycle
May 03, 2009 | GE Profile Prodigy WPSE4200A
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
GE WBB4500EWW Top Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
