Question about Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412
I have four showers that uses a Grohtemp 34 901 thermo controlled rough in valve in a recently built house. From first installation the temperature of the water coming out of several of them was WAY off. Setting it to 70 gets you 100-105 degree water. The hot water going in is roughly 140-150 degrees so its hot (solar heated and probably hotter now as its summer). Lately the water coming out of one of the showers when set to the minimum (70) has gotten even hotter-to the point of being unusable-feels like 105-110 degrees. Is there some kind of adjustment or calibration setting for this valve? Or does it just need a new thermostat cartridge? I have another shower that acts similarly while the other two seem to work ok-the water coming out seems close to the setting you've set it to. They two wonky ones have been like this since the house was built so they never worked right. Any ideas of what's going on with these two valves and how to get them working right? Thanks
2 Suggested Answers
  • 1015 Answers
SOURCE: My Grohmix 19 421 thermostatic
The problem might be fixed by removing the cartridge and cleaning it thourghly and resetting temp stop.Yes the cartridge could be bad but new parts are readily available. Depending on water quality conditions in you area it may be difficult to disassemble so it may be a good idea to have a plumber do it for you. Thank you.
Posted on Mar 03, 2011
How do I adjust water temperature after valve has been installed
Don,
there be should be a knob (typically red in color) on the front of your water heater, with temperature degrees listed. The knob should also delineate a typical range of settings for domestic use, which range from 120 degrees to 160 degrees. While a hotter setting will allow an increased amount of warm water, for example for longer shower duration, these temperatures can present a risk of scalding and require more energy to maintain the selected temperature.
EJ
Nov 02, 2014 | Grohe Grohtherm Thermostatic Rough-In...
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I have a grohe power shower wich only has cold water coming out. if i replace the thermo catridge will this solve the problem
It has been a while since I have worked on a Grohe, But if it has a built in scald gaurd or thermo cartridge, it may be sticking and need to be replaced.
May 02, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I'd like to install 1 shower had and one hand held shower. What do I need to have ?
well you can do a 3 way shower valve , or a mixing valve with 2 control valves. or you can do just to regular shower valves one for each of the heads you want one for the rain and one for the shower head. this way is cheeper and you can have one on hot water and the other cold water or the other way around or both the same temp.
Apr 26, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
The temperature in my shower is very luke warm only at the shower
Do you mean the other faucets in the house are hot and only the shower is warm? If so there is an anti-scald adjustment on the faucet that needs to be turned up a few notches. Havent adjusted a Grohe faucet but most faucets you rmove the handle and behind the handle is a nothced adjustment ring that prevents the faucet from getting too hot. This ring, or stop, is pulled out and twisted clockwise(or counter clockwise to set higher or lower max temp, then pushed back. maybe you can look up grohe to see which way ring or stop adjusts for hotter water.
Jan 23, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
We have a Grohmix shower valve and we are unable to adjust the water temperature. Any assistance would be appreciated.
Oct 20, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
How do I remove grohe shower trim?
norm cover levers off go round cover at four points
Oct 14, 2009 | Grohe Integrated 1/2'' Shower Thermostatic...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Grohe Integrated 1/2'' Shower Thermostatic Rough-In Valve With Stops - 3412 Logo
    210 people viewed this question
    Top Grohe Water Heaters Experts
    Paul Carew
    Craig Butler
    Craig Butler
    ray gallant
    Are you a Grohe Water Heater Expert? Answer questions, earn points and help others
