Question about Pioneer PRO-700HD 64" Rear Projection Television
Images getting darker... ~ 10 yrs old
My 700 was the greatest almost 10 years ago when I got it. I don't know if it has degraded over time, or I am imagining things with the brightness of the newer TVs these days. DVDs, digital channel movies, and HD channels seem to come in very dark and I can't differentiate blacks from dark grays. Weird thing is that when commercials come in they come in nice and bright. Suggestions? what do i repair? Please don't say replace with a nice 60" flat panel...
Preciso un plastico exterior de pantalla.
Posted on Apr 27, 2008
  • Pioneer Master
  • 8,617 Answers
I wouls sggest polishing the mirror and CRT lenses. This can have a big effect on brightness. If that doesnt help you may need to change the CRT coolant in the CRTs as 10 years is a long time if the coolant has never been changed and that will improve the color and brightness to like it was when new.
Sam is 5 years old...his older brother Tom is 3 times as old as Sam...when Sam is 20...how old will Tom be?
Well, Tom is 3 x 5 = 15 yrs now. Sam has 15 yrs to go to 20. Then Tom will be 15 + 5 = 30 yrs.
Or, Tom is 10 yrs older than Sam now, so when Sam is 20........
May 15, 2015 | GPS
How was mauna loa formed
OK, the whole Hawaiian Island chain is volcanic, formed from volcanoes which rose in turn from the ocean floor, erupted, formed an island around, then became less and less active in turn as the whole island chain moves away to the NW at 2 - 4 in per year.
Mauna Loa is one of 5 volcanoes which have formed the main island Hawaii. It is still active, and is a wide flattish volcano 4169 metres above sea level (13 679 ft).
It probably started erupting under the sea about 700 000 yrs ago, and rose above the surface about 400 000 yrs ago. It is a young volcano in geological terms as the oldest rocks found on its surface are 200 000 yrs old.
There is heaps more info here, but take care as some teachers do not like you to quote Wikipedia as a reference.
http://en.wikipedia.org/wiki/Mauna_Loa
Sep 19, 2014 | The Learning Company ClueFinders 5th Grade...
Samsung Ln-T4671F screen is getting darker. The whole screen is darker, not only the right or the left. Also a red vertical line appeared about a year ago, haven't noticed since- don't know of its...
MOST LIKELY YOU HAVE A DEFECTIVE LCD PANEL. Try lightly squeezing the top of the TV. Start from one corner and work your way slowly to the other side. If squeezing the top of the frame clears up the screen problem, you have a defective LCD panel tab. The only true repair is the replace the screen. This cost for a replacement panel could cost more than a new TV set.
Sep 03, 2012 | Televison & Video
I have a 10 year old White Westinghouse washer. I don,t know the model #. It is heavy duty. Is it direct drive , or is it belt driven
Its belt driven only washer made by the Whirlpool corp. were direct drive during that time period 10 years ago
Sep 14, 2011 | Westinghouse Washing Machines
I bought this tv 6 years ago, it was manufactured in 7/2003. I just started experiencing a double image problem, and the color is a little bit off. Is it worth getting fixed?
It sounds like the fluid in the projectors has possibly degraded. Sometimes there are settings you can use to adjust your T.V. If that doen's work, then it costs about $700 or so to replace the fluid in the projection tubes.
Dec 01, 2009 | Mitsubishi WT-42311 42" Rear Projection...
We are getting ghost images and the color is not correct
I have red concave lines going across the screen, plus wording appears double like a ghosting effect, this is ongoing from the time the tv is turned on until it is turned off. This started 3 days ago. Is it time for a new tv, its 9 or 10 yrs old now.
Mar 29, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Aprilaire Model 700 - not achieving 40% humidity
if it is set up right, you should be able to run your fan 100% of the time and the humidifier will come on when there is a need for humidity. you can experiment with leaving the fan on and see if this helps. it will run your electric bill up a little and also you will have a lot of waste water. that is a drawback to the bypass type humidifiers. also a factor is if the water supply is hooked up to the hot or cold side. it will humidify better on the hot side, but you tend to get more deposits that plug the solenoid over time and you will be running your water heater quite a bit. 1600 sqft may be pushing the limit of this humidifier.
Jan 24, 2009 | Aprilaire 700 Humidifier
Pioneer PRO-700HD 64" Rear Projection Television Logo
134 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
