Question about Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3
Neither of the batteries for my Hitachi DS 180FL will hold a charge. I bought the drill on February 4, less than three months ago.
Your batteries may be old or some of the cells may be no good. Dis-assemble and check each cell individually. You can replace bad cells as they're very inexpensive.
Posted on May 23, 2008
    Champion:
  • 313 Answers
Take the unit to nearest hitachi service depot & don`t forget your
receipt
Posted on May 28, 2008
My cordless black and decker bateries HPB18-OPE WILL NOT HOLD A CHARGE
These drills are cheaply made and are fairly cheap.
I asked the store where I bought mine and he said he would get me a new battery. He wanted thirty four dollars for the battery and I only paid forty bucks for the whole drill a year ago.
I learned something
I bought a Ryoby at 149 dollars and came with two batteries. I keep a battery plugged in all the time and switch them once every two or three weeks. I bought this one three years ago and it is working like it was three years ago. I just leave it plugged in all the time. The cheap B and D won't last very long.
Apr 12, 2015 | Drills
I purchased a Ryobi drill with Lithium batteries (Large/with gauge, small without gauge) in June 2009. The large battery lasted about 3 months and started holding less and less charge (yellow, then red on...
Batteries must be completely dead before recharging or battery life is shortened.large battery is probably defective contact Ryobi to replace battery they while probably send you new batteries for free if you tell them you are going to stop buy their products.Tell them about both batteries they will probably replace both for no charge
Jun 12, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
This is the second Ni-MH battery I've bought that I've used infrequently over the last year and now it doesn't hold much of a charge after I charge it. Some people say I shouldn't leave it on the charger...
Any battery should start charging for over 8 hours and then it goes down to 4 hours, however no one working on a job wait 4 hours to get the batteries charged so they start cutting time and for that it get less and less charges inside and after a while it refuse to take any charge..Drain your batteries totally, charge them over night, see if that work if not just use them tell you are done with them, and get new equipments not new battery. When buying new equipments and charging them remember never use it until you fully charge it for 8 hours and not even use it for a second before it’s fully charged... Let me know if that work for you and please do not forget to rate my service so I can keep providing this service to everyone and improve on it. God bless
Sep 21, 2009 | Drills
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
Hitachi 12v 3/8" Driver Drill Kit with Flashlight DS12DVF3 Logo
267 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
