Question about Refrigerators
Not keeping cold enough reading 26 degrees in freezer and 50 degrees in refriger lower area.clean condenser coil by blowing out area fan at conderser is working compresser working cold air blowing out in freezer reading 26 degrees.is it low on 134a and if so how do i chargeit without a port. and why is it low beening only 3 years old
    President:
  • 1,099 Answers
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 – Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Good luck, Hope this helpout.....
Posted on Aug 07, 2010
Freezer only gets down to around 18 degrees but fridge is fine. No frost on the freezer evaporator fan is running
Modern consumer refrigerators only have coils in the freezer. In the lower back of the freezer there is a small fan and possible a damper (flap that opens/closes) to push cold air from the freezer to the refrigerator. Given that the freezer is 18 deg, it's probably cold enough to keep the fridge area at typically 34 deg.
So the cooling system (compressor, coils, thermostat) are not working properly to keep the freezer at, typically 0 deg. Possible causes: partial loss of refrigerant gas, icing around evaporator coils (in freezer), compressor failing, dust clogging condenser coils (under fridge), condenser fan clogged or broken (under fridge), thermostat failure.
I'd start with condenser. Remove the slotted trim at the bottom front and look in with a flashlight. Are the coils clean? Pull out the fridge and remove the lower back cover (usually cardboard). You can now see the coils and fan. Clean and blow them out.
If it's icing, it probably means freezer door not closing tight. If auto-defrost not working properly it would probably get worse over the period of a few days so not likely.
Apr 21, 2016 | Frost Refrigerators
Top freezer cold, lower part 40 -50 degrees, vacuumed condenser already, what part blows coldness too refrigerator area?
Check for ice build up in the rear of the freezer if so defrost unit and the fan should come back on
Sep 05, 2015 | Refrigerators
My refrig and freezer wasn't working good, i replaced the heater that goes underneath the coils. now my problem is the freezer is on 0 degrees and the refrig is on 60 degrees, i noticed the flap that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 28, 2011 | Refrigerators
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
I have a model GDM-26. It's was blowing really cold, 30 degrees, then warm, 50 degrees, alternating between the two. Now it's not blowing cold at all and the coils on top do not get cool/cold. Both...
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Jun 29, 2011 | True GDM-26 Refrigerator
Frigidaire top-mount refig. freezer won't get cold ,temp.stays around 26 degrees, refrig. don't keep milk cold enough
check that the evaporator fan motor ,located in freezer is working.it circulates the cold air.also check that the coils behind freezer back panel are not iced up,this would indicate a lack of defroting due to,timer,heating element,or bi-metal.lastly when the refrig is running those coils should get frost over them all,if not you may be low on refigerant
Jan 20, 2010 | Frigidaire FRT17G5CSB Top Freezer...
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
