Question about Car Audio & Video
Kenwood W3537A CD receiver connected with power leads yellow and red reversed. CD will not accept a CD now that the leads are connected correctly (this was not very clear in the manual) Its a Volkwagen car. any ideas tuner works OK but the CD drive will not accept a CD it wirrs and forces the CD out if you try to insert it.
  • zen128418 Apr 27, 2008
    Its very difficult to get a CD into the unit it keeps forcing it out I got a TOC ERR on one CD but not on another. The IN light is flashing and when you switch the unit on via the SRC button it only gives you the Tuner option or the standby option it does not scroll through the CD external disc Aux input etc when you depress the SRC button.
    should have got a panasonic!
  • 19,396 Answers
What message did you get when putting a cd inside
Posted on Apr 27, 2008
  • Ginko
    Ginko Apr 27, 2008
    This problem is unlikely related to speaker or power connection. Try with different CD , just in case it is a defective or dirty disk.
    Generally, when the drive does not read a cd is a lens problem, in this case clean the lens, first manually, then taking apart the device. If this does not work it may be a damged lens pickup, in need of replacement.
    Check also that the eject button is not stuck
IDC 248u. Why does it lose station memory?
Review the installation instructions. Connections may have been reversed.
Nov 06, 2015 | Kenwood Car Audio & Video
Wiring diagram
Red is Positve = +
Black is negative = -
Yellow is the backup - If the backup is not connected, the radio station will lost it memory if ignition is turned off, and cd will start from no 1 and won't continue when it was last played. - Yellow must be connected to the Battery or positve wire which does not switch off if the inition is off
Oct 02, 2014 | Kenwood KDC-319 CD Player
There is power to my kenwood radio as the cd player will accept and eject a cd but there is no lights on the radio face plate and i cannot get any musi out of it
You might want to make sure you are getting power to the red wire. The radio will accept and eject cd's if power is going to the yellow wire only. Both wires have to have 12v going to them before the radio will work properly.
Aug 05, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
My faceplate will not work... the base works and has power but the faceplate stays blank. What can I do?
are you sure you have power going to both the red and yellow wires? the deck will accept and eject cd without power to the red wire, but will do nothing else.
Oct 27, 2010 | Kenwood KDC-419 CD Player
Why wont my personal setting save for my Kenwood KDC-X493 car CD reciever? This is my 2nd aftermarket cd reciever and just like the 1st one I'm still having this problem.
Make sure you have the +12VDC and the Ignition leads hooked up properly.
If your head unit is pulling is power off of the IGN lead, it will reset every time you turn your car off.
Dec 31, 2009 | Kenwood KDC-X493 Car CD/ MP3 Player
Inline and unit fuses ok,still no power to unit
try switching red and yellow leads at back, red is switched feed from ignition, yellow consent feed if these are both there, unit proberly fried
Dec 04, 2009 | Kenwood KDC-MP205 CD Player
Kenwood KDC-MP2032 radio wiring color
YELLOW goes to the battery lead
RED goes to the ignition on lead
BLACK goes to chassis ground
Apr 05, 2009 | Kenwood KDC-MP2032 CD Player
Kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
May 27, 2008 | Kenwood KDC-2011S CD Player
In my 1995 Chevy Lumina
check if you're getting power to the red and the yellow, it may be that you are only getting a permanent live but no switched live and if so you will need join the red and yellow on the radio side together using the connectors on the loom so you will have one permanent live leading into two (red and yellow) wires into the radio. clear as mud, good luck
Dec 06, 2007 | Kenwood KDC-135 CD Player
Cdx-mp40
You are correct, the unit powers entirely from the red and yellow leads. Your symptoms sound like a unit that isn't getting power on the red (switched) lead. The most likely cause is a blown fuse in your vehicle's fuse box.
Mar 13, 2007 | Sony CDX-MP40 CD Player
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
