Question about Waring Kitchen Appliances - Others
Need user manual for waring pro wwm200pc waffle iron
Jerseybob
  • 18 Answers
SOURCE: Waring pro waffle maker
I personnally just went through this.
If it is less than one year old, and you have the receipt, go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
My replacement had a silver body virsus the original black body. The shop told me they have yet had a customer repeat of this problem.
Posted on Apr 02, 2008
Jerseybob
  • 18 Answers
SOURCE: Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
SOURCE: removing top of waffle maker to clean it
The other night my wife had the same issue. My thought had always been to wipe it down using a wet cloth with simply hot water and rely on the extreme heat of using it to sterilize it.  My wife decided instead to disassemble it.  The problem is that it is not made to disassemble and she bent some parts and broke others and stripped out screw heads.  It is clean now, but can not be reassembled without extracting stripped screws and replacing some parts. My advice to you is - don't try to disassemble it. The factory went to great lengths to ensure that you don't.  Instead use a soft cloth dampened (not dripping wet) with the hottest water you can.
Posted on Dec 29, 2008
  • 5 Answers
SOURCE: Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Posted on Mar 09, 2009
  • 492 Answers
SOURCE: waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Posted on Apr 30, 2009
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
No manual with Waring Pro 300A waffle iron. Bought today 5/20/10 at Bed Bath & Beyond
Here is the online (pdf) manual for the WMK300. If hope it is similar to the 300A.
May 20, 2010 | Kitchen Appliances - Others
How do I season my Waring pro Waffle Maker?
Teflon coating does not to be seasoning , but you will need to use a spray shorting like PAM before you make each waffle
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
Broken shaft
I made a template of the shaft, cut out a sturdy piece of tin to straddle the break, and then screwed that piece in at both ends after securely fitting the break together. A lot of work, but the waffle maker works great!
Dec 13, 2008 | Waring WWM200PC Waffle Maker
Waring Wafflemaker power light comes on but won't heat up
My just over 1-year old WWM200SA did the same thing while I was cooking with it (used it about 5 times). I found a solution under the WWM200PC thread that the thermal fuse blew early. I tested mine and that's what happened. It is a cheap part, but I called Waring Customer service (800-269-6640) instead and they said to send it in for replacement.
Apr 21, 2008 | Waring WMK300 Professional Belgian Waffle...
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
WWM200PC Waffle Maker will turn on but does not heat up
I fixed one of these for a friend - the problem was an open thermal fuse. This fuse is located in the fixed grill; it is clamped to the grill and is covered by a white plastic sleeve.
The replacement part should be a 240°C/464°F 10 - 15 Amp thermal fuse. NTE sells a part NTE8242 which works available from Mouser.com for $1.41 plus shipping.
May 25, 2007 | Waring WWM200PC Waffle Maker
Kitchen Appliances - Others Logo
185 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
