Question about Dometic Rooftop RV Air Conditioner
In a late 1970-1980's duotherm a/c, what freon needs to be put into the ceiling unit?
    Top Expert:
  • Dometic Master
  • 8,861 Answers
Cannot add replace unit
Posted on Oct 06, 2017
2 Suggested Answers
icemelts
  • 246 Answers
SOURCE: domedic duotherm 13.5, comp runs but no cool.
From what you've told me - I'm now thinking you're low on freon, and my advice (to you) would be to call a Service Tech who can (a) find the leak (b) fix the leak and (c) re-charge the unit with the proper charge.
Of course you can always put a 'tap valve' on the AC and try to charge it yourself - but unless you have experience with this kind of work, and the proper tools, i.e. gauges and welder - you will not be able to repair the leak (it will almost invariably need welding) - or properly re-charge the unit.
In any event - if a 'leak' is your problem - you should be able to get a Service Tech to fix it for you - for around $100-$150 without a problem.
good luck!
Posted on May 17, 2010
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
Aug 20, 2015 | Coleman Heating & Cooling
Does the fan shut off on dometic ceiling cover control model
that would depend on the fan setting of your thermostat
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Our Goodman inside unit has an accumulation of ice on the Larger of the two lines from the outside unit. A thermometer in the grill in the ceiling indicates that the temp at the grill is 76.4 F even with...
it starts with dirty filter if this is good it could be dirty coils if it passes could be low on freon but before you add you need to insure both fans and compressor are working but most commonly it will be dirty coils
Sep 17, 2010 | Heating & Cooling
Domedic duotherm 13.5, comp runs but no cool. looked at unit to find schrader valve... not there. does piercing tool work for adding freon. all else appears on good condx. I think it just needs gas. does...
if compressor is comin on an you r sure then you are low on freon,there is not a port to put freon in you would have purchase a tap valve on the bigger line then apply freon to it ,thats located inside of the system
May 15, 2010 | Dometic Rooftop RV Air Conditioner
Roof air unit too loud inside; quiet outside.
When you say loud, do you mean as in airflow noise, or vibration like noise? I take it this is a ducted system as well. Does it have quik cool option on ceiling assy.?
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
No cold air. Unit runs fine.
There are a variety of probable causes of your AC's failure to blow cool air. Unfortunately, it is difficult to diagnose your situation without being there. However, I have a great, handy diagnostic article that specifies the main problems so that you can definitely come to find the cause applicable to your AC's failure. I'm not too familiar with RV AC's and how they may differe a bit from house AC's, but your AC very well may need a recharge of refrigerant/Freon by a technician, but short of that, try this first:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
This should defintely help.
Brad
May 28, 2009 | Dometic Rooftop RV Air Conditioner
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
A/C compressor won't engage
have you had you freon checked?? there is a safety on that compressor if your system gets to low it will not allow the unit to run.. irongod
Apr 05, 2009 | 1999 Chevrolet Silverado 1500
Install a second DuoTherm A/C in a fifth wheel travel trailer.
You do not without removing wall board. You can do a nice neat job of white conduit on the outside of the wall and ceiling. I have done it and my customers are happy with it.
www.coachtech.info
Mar 19, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
107 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
