Question about Bunn BT10B Coffee Maker
Bunn b10-b neads new heating element assembly and can't find one on internet. will not keep reservoir heated.
  • 189 Answers
Unfornately, the heating element is not repairable. If you will call 800-352-2866 with your model and date code, we will be able to further assist you.
Posted on Aug 16, 2010
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn coffee maker model gr10-b water will not heat in tank
If you will call customer service with the model and date code at 800-352-2866 we will be happy to help you with this issue.
Oct 17, 2010 | Bunn B10 Coffee Maker
My friend gave me a Bunn thermal home coffee maker and I don't know how to make it work and can't seem to find directions on line?
Depending on which maker and how old it is it may have a switch for the heating element. The BUNN brewers have a reservoir inside that needs to be topped off BEFORE energizing the heating element/plugging it in. This usually will require about 3 pots being poured through until water starts to flow from the filter basket. (Have a pot in place to catch the water) Then it is safe to plug in your machine. After it heats up (about 20 minutes) you can load your grounds and pour through a pot of COLD water and voila... coffee.
Also, due to the reservoir you will want to not shut off or unplug your brewer... then it will be ready to brew next time.
Sep 20, 2010 | Bunn 10 Cup Home Coffee Brewer
I have a bunn coffee maker that when it brews the first pot is hot after that the next one is not. It is the coffee maker that has two warmers on top. i didnt know if would be the heating element or...
While this brewer does have a reservoir that keeps a couple of pots worth of water hot for brewing you can get a cooler second pot if you brew directly after. You should hear the brewer heating up after brewing. Try waiting until it is back to temperature before re-brewing. If that heating takes more than a few (3-4) minutes then you probably have a problem with the heating element and the water is only being heated by the "keep warm" heater.
Sep 13, 2010 | Bunn VPR Coffee Maker
Bunn VPR Series Coffee Maker will NOT dispense the water into the coffee pot?
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Sep 10, 2010 | Bunn VPR Coffee Maker
Lukewarm water...tank empty...how do I fill it if it is supposed to fill automatically from an outside line?
It looks like this brewer has a fill lid on top. If you remove the screw on the lid you can remove it and pour cold water through (1/2 gallon per pot). If the brewer was energized and NOT filled with water before hand there is a good chance that the heating element burned up. The reason you would still get "lukewarm" water is due to the keep warm heater around the tank. It is a low voltage warmer that keeps the reservoir warm without the main heating element kicking in.
Aug 25, 2010 | Bunn CRTF5 Coffee Maker
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
BT-10-B Bunn Thermofresh that will not heat or fill pot
Lots of times minerals clooect on the heating element and inside the heating chamber. The easiest thing to try is to put white vinegar into the filler, displacing some of the water into the pot. Leave this to soak for about an hour, then flush with several pots of water until the vinegar smell cannot be detected in the water. Make sure that the switch on the side is "ON". You may have an indicator light. The switch on the upper front is for the warmer. The reason you only got a partial pot of water is that the reservoir wasn't completely full. Once you have filled it completely, you should fet a full pot out for every full pot in. If all of the above gives you no relief, you may need to test the heating element for voltage and continuity. If it tests 'open', you will need to replace it.
Good luck, --W/D--
Jul 17, 2009 | Bunn B10 Coffee Maker
I have a bunn coffee maker, BT10-13. The reserve water takes very long to reheat after making a pot of coffee. Thus I can't make a second pot of coffee for a long time.
Are you rapid firing your coffee maker?Not designed to do that.. If the water heated that fast it would boil dry if you ever left it unattended and on. The reservoir is heated with the time it takes to drink a full pot taken into consideration for reheating.. If you are serving 20 cups with a 10 cup machine, Expect a delay, especially if you are refilling with cold tap water. Sorry.
Jun 30, 2009 | Bunn B10 Coffee Maker
Bunn coffee maker reservoir makes a gurgling noise
THis sound is usually caused by the water being low in the tank. This can be because the machine is left on for long periods without being used. If this is not the case, then it would probably be your heating element getting small holes in it.
Jan 12, 2009 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Bunn BT10B Coffee Maker Logo
439 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
Marvin
Marvin
evans_lloyd
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
