Question about Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer
I have a amana washing machine model numbert is LW6111WB,THE problem is after washing and while letting out the water I see water running from underneath. When I pull the front,upon close inspection I see the entire top of the pump wet and water running down the side ,I check both hoses that are attached to the pump and they are ok,so my conclusion is the pump,how do I take it off? Also ho do I change the belt?
  • 163 Answers
SOURCE: change belt.
this is a easy job for a tech but a hard one to regular people have to remove the transmition and thats is by removing a nut in the tub, so better call a tech and pay for it, is not to espensive repair at least in my area...good luck
Posted on Aug 07, 2006
  • 1028 Answers
SOURCE: Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Posted on Jun 05, 2008
smartr10U
  • 1305 Answers
SOURCE: amana nav5800aww water on floor after spin cycle
Sounds very similar to having something such as a sock or small article of clothing that is too large to be sucked down the drain hose into the pump. So what happens is it hangs around between the inner and outer drums and sometimes gets itself lodged over the drum drain hole, and can allow water to be centrifically flung over the top of the drum. Most times when the spin cycle stops, the article of clothing will dislodge and float around inside the drum only to do it again later....
If you can remove the top of the machine, you can usually see the gap between the two drums and use a piece of coathanger wire with a small hook on the end and "go fishing in the area between the two drums and close to the drain hole location... bet you'll find something in there... Let me know how it goes... and if I can help .. ken
Posted on May 10, 2009
  • 125 Answers
SOURCE: can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Posted on Aug 23, 2009
  • 901 Answers
SOURCE: install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Posted on Apr 06, 2010
We can hear water running but it's not filling the wash tub. There is no water leaking anywhere.
check that the tap is fully opened , the filter in the end of the hose is not blocked
check that the tap washer is not jammed off in the tap as they can expand and not move up to let water in
check water inlet solenoid is functional
Aug 23, 2015 | Amana DLW330RA Top Load Washer
The little door that opens to let water into machine(front loader) does not open. Why?
Links to sears parts direct. First link is to download manual, see page 11 Clean dispenser.
NFW7200TW10 AMANA RESIDENTIAL WASHER Manual
Second link is to parts diagram. images can be changed in size.
Second image from left is the dispenser.
AMANA Residential Washer Parts Model NFW7200TW10
Sears offers trouble shooting help also look for trouble shooting in user manual.
Sep 21, 2014 | Amana Front Load Washing Machine Washer...
I have an Amana front load washer, it will run through a complete cycle when empty but will not run with a load in it.
Hi Ben
I see you have posted on this before , I think you may have done this already judging from your post , but have you checked the filter on the drain pump? also when you run a cycle empty, is it filling and draining the water correctly , or is there water left in the machine , and last is the drain hose high enough to make sure that there is not a "syphoning" effect taking place as in when it fills with water it drains at the same time , just a thought let me know.
Oct 13, 2017 | Amana Front Load Washing Machine Washer...
Amana lw8303 clothes washer will not run or drain
I had similar situation. and changed out the water pump on my washing machine. it works great now.
Aug 29, 2012 | Amana Washing Machines
Slow filling Model lw4303wi
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 15, 2011 | Amana Washing Machines
Amana washing machine will not spin. it agitates & the water drains out fine.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 30, 2010 | Amana ALW780QA
The amana washing machine model lw6501w2 fills with water and starts agitating and spinning at the same time during the wash cycle. This causes the water to spill over the top and run out the bottom.It...
Sorry that does not sound right,,. there should be interlocks that stop agitating and spinning from happening at the same time. go to the dealer you bought it from and tell them and there may be a recall for your problem and they may replace your machine at no cost or low cost to you no matter how long you have had the machine,at least in theory..
Oct 19, 2009 | Amana Washing Machines
I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Nov 22, 2008 | Amana NAV2335A Top Load Washer
Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub Washer Logo
62 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
