Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
When we intially set up the Salt Water System it worked great... Then after about a month and a half, the water started to get cloudy. The system kept giving the "91" Low Salt code and beeping. We then added the right amount of salt and let the pump run for the instructed time. However even after changing the filter and vacuuming the pool we still constantly get the "Low Salt" reading. It is very frustrating since we have only had the pool about two months and our system is not working... HELP!!
  • 297 Answers
Way to much to type for a non typeist
Please look up my name and look at my posts on green water,low salt, and low flow
All of my posts will be very helpful
I am positive of this
Mark
Posted on Aug 08, 2010
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Our pool is cloudy, we got rid of the alge but cannot clear the pool. Have had this system over a month and still not clear . Followed install directions but no luck
This is a sign of not running the system long enough... 1st, make sure you have the correct amount of salt... The manual is very conservative... I have a 18 X 33 oval pool and I run my pump in the summer at 10 to 12 hrs with the chlorinator at 8 to 10 of those hrs and have very clear water.. If I drop from those hrs, my water starts getting cloudy and the sides of the pool get green...
Hope this helps and if it does, please rate!!!
Jul 25, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says salt level low.....it seems salty enough as I can feel and taste it. Is there chemicals I am supposed to be adding or does this system keep it clean all alone just by adding...
While your problems are likely greater than just the salt content in the water I can tell you that if you feel, or more importantly can taste the salt in the water your salt level is WAY TO HIGH, not low. Have the salt level confirmed with an independent test either at a pool store or using a salt tester.
John
Jul 21, 2011 | Intex Automatic Salt Water System for ...
After 5 days using saltwater system water is cloudy. Before installing new system no cloudy water. Help.
Intex salt water system does not keep your pool cleaner. It is only a means to not have to buy liquid or tablets
If your salt is not at 3000ppm not below 2700 not above 3800 you will not generate enough sanitizer ( chlorine )
You need a good stabilizer to help hold chlorine content and a good non foaming algecide which you would use every 5-7 days
Don't forget chlorine consumption is caused by many factors.
# of swimmers, heat, sun, rain, did any one sneak in with sun tan oils and so on and the worst thing for a pool is to not use it on a daily basis.
Get your money back on the salt system and go with what worked for you.
Jun 25, 2010 | Intex Automatic Salt Water System for ...
Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Water not clear
cloudy water is mainly due to poor pool maintainence.
Your purchase of the salt water system only helped you with not needing to pour chlorine in or float tablets.
You will still need to use chemecals.
I use a good stabilizer to hold the chlorine level longer
I use a non foaming algecide once a week
I also use a water clarifying product once a week
Now on to the clouds :-)
cloudy water is because of not enough sanitizer mixwd with a crappy pump from intex
I do not know the size of your pool so I will just use mine to show you #'s
I have a 7000gl pool with a 2500gl ph pump
A pool needs to be turned over at LEAST 3 times a day so for me it takes at least 8 hours of filtering alone this does not include making chlorine.
Bottom line is you should run your system 24/7 between generating and straight filtering
The only cure for less filtering is to get a sand filter with at least a 1 horse power pump to pump 4000gl and uphaving a sand filter helps trap more small particles than the cartridge filter.
I noticed the difference the first night I had my sand filter. It ran for 6 hours before me turning my pool light on and to my surprise I did not see as many particles passing my light as with the cartridge filter and the second night nothing Crystal clear.
Bottom line is intex pumps and so on are not big enough for the pool it comes with.
The salt system alone with a sand filter is great
Jun 26, 2010 | Intex Automatic Salt Water System for ...
I JUST SET UP MY INTEX SALT WATER SYSTEM AFTER DISOLVING 140 LBS OF SALT IN MY 18' X 48" EASY SET POOL. AFTER ONLY RUNNING FOR 2 HOURS, IT STARTED BEEPING LOW SALT. DOES THIS SOUND RIGHT AFTER JUST...
It is possible that you do not have enough
even after disolving the salt by siring it up you need to run the filter for at least 24 hours to really disolve and mix your salt
even though you cant see it it is still not equally distributed through the water
once you have run the system for 24 hours check your salt content
It should be as close to 3000ppm as possible
a test kit will cost about 11 dollars for ten tests
Jul 22, 2009 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Code 93 saltwater system
Hi, Code 93 is telling you that the system is done running, did you mean to say it said 92? That code would be for too much salt. If indeed it is a Code 92 you are getting, give Intex a call, or email. I have found their website to be very helpful, they have a F&Q's area. Good luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
420 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
