Question about Palm Treo 755p Smartphone
How do i do a hard reset on a Palm 755p - Palm Treo 755p Smartphone
Take the battery out. press the red button down and without releasing it, put the battery back in while still holding the red button down. It's a little awkward but works.
Posted on Sep 29, 2010
Palm 755p Malfunction
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your Treo, so only do it if you have to. Google how to and it will work perfect.
Feb 06, 2010 | Palm Treo 755p Smartphone
I locked my phone now the password is not working and my phone is locked. Would you tell me how to unlock it without a password?
Hard Reset Palm Treo 755p or 700pPalmTreo2_bing.gif 755p or 700p.
1. Disconnect the Treo from a charger or USB cable2_bing.gif.
2. Remove the battery cover and take out the battery.
3. Press and hold Power/Endwhile you insert the battery.
4. When the screen lights up with the logo appears, releasePower/End.
5. Press Up when the Erase all data? prompt appears.
6. Press Up to confirm the hard reset.
7. Go through the steps of setting up the device again by picking a language and calibrating the stylus.
Now your Treo 755p/700p is hard reset. you should have your info on a folder on your computer. hope this helps.
Jan 23, 2010 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
My palm 755p has the red, blue, white and green blocks what do i
NEED TO DO A HARD RESET ITS GOING TO ERASE EVERYTHING AND ITS GOING TO GET RID OF THOOSE PROBLEMS! JUST PRESS AND HOLD THE RED END BOTTON AND AT THE SAME TIME PULL THE BATTERY (KEEP UR FIGURE ON THE RED END KEY) THEN PUT THE BATTERY BACK, AND IF I WERE U I WOULD DO A SYNC EVERY WEEKEND!
Sep 28, 2009 | Palm Treo 755p Smartphone
How do you hard reset on palm treo 755
Hard resets on a 755p are described in the user's guide as removing the battery (with the phone off, and screen off), and then pressing the Navigator-UP button and holding until you insert the battery again, and you see the Orangle PALM logo displayed, where you can release your Nav-UP button. This does not work.
You need to hold down on the red power button, until the Orangle PLAM logo shows up, release it, and you will see a question like "do you want erase all of your data?" , press the Nav-UP button, and it will now do a clean hard reset.
Now, on the backup folder.
If you do not change user-names, and your PALM Hotsync setting for 'Backup' is set to 'Desktop overwrites handheld' you will get everything back when you HotSync. Therefore, if you delete the problem App's from your Backup folder (ie C:\palm\755p\backup, where 755p = your HotSync name) and you change to the settings on 'Backup' to 'Desktop overwrites Handheld' - then when you hotsync, you'll get the app's you want back, and not the ones you do not.
I hope this makes sense.
Sep 18, 2009 | Palm Treo 755p Smartphone
'incompatible installer' 'Uninstall now is ok'
If Palm Desktop is installed, try upgrading it. Also there may be something wrong with the connection cable.
Aug 26, 2009 | Palm Treo 755p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
It will not go away from the sync screen mode
Apr 07, 2009 | Palm Treo 755p Smartphone
Tried the hard reset for Palm Treo 755p. It asks to erase data. I say yes. And then nothing else happens. Anyone try anything else? Is the phone done?
yes it is hard reset already it is the normal behavior
pls rate me fixya for the help i provided or tell me ur issue in detail if u want anything else
Mar 04, 2009 | Palm Treo 755p Smartphone
Frozen Screen on Palm Treo 755p
mayb you can try to do a hard reset.
Take out your battery press and hold end call button ( don't release ) then put in your batery wait the loading finished and change to other screen then you release your from the end call button you pressing just now.If still can't work,no choice need to go back to you service center .
Dec 28, 2008 | Palm Treo 755p Smartphone
Palm Treo 755p Smartphone Logo
43 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
