Question about Sony VAIO VGN-FS630/W Notebook
What is the largest HDD compatible on a Sony Vaio VGN FS630/w laptop What max HDD size can I upgrade now? Currently my laptop has 80GB HDD.
    Guru:
  • 1,082 Answers
This is a 5 year old system which is ancient in todays world. Upgrading the disk to 160gb would help but that is about the top end disk size. I'd consider a newer system. It would cost in the $75-100 range. Your disk is ATA which I don't think got larger than 160.
Don't forget you need to CLONE the existing disk to the new one which can be a pain if you don't have the correct tools.
Posted on Aug 07, 2010
Testimonial: "I really regret replying late - but I have had a great insightful reply from you Jim :) thanks again. Although I still haven't fixed this laptop over a year now - shall plan to fix it this week. "
  • 1 more comment
  • moronz Aug 08, 2010
    Thanks OldSoftware, kindly tell me what do you mean by cloning the disk, since I have the backup of the original installation. I can do a restore, is that what you meant?
    Also - are there no ATA Laptop HDD sizes larger than 160 GB. ?
    Reply awaited.
    ~ moronz
  • Jim Winger Aug 08, 2010
    ATA disks topped out in the 160GB range when SATA drives, which have a different connection, started taking over. They get much larger.
    Cloning is an EXACT copy of your disk, not a backup. This means all your software runs just as it used to, settings are the same, XP keys are OK, etc.
    Laptop disk cloning is usually done with a special machine or your put the new and old disks with a special cable in a desktop and run a cloning program. Many disk manufactures include a cloning program with new disks. Desktop cloning is easier since most desktops will hold two disks.
    Mobile HDDs, i.e., laptop HDDs, which are physically smaller than their desktop and enterprise counterparts, tend to be slower and have lower capacity. A typical mobile HDD spins at either 4200 rpm, 5200 rpm, 5400 rpm, or 7200 rpm, with 5400 rpm being the most prominent. 7200 rpm drives tend to be more expensive and have smaller capacities, while 4200 rpm models usually have very high storage capacities. Because of physically smaller platter(s), mobile HDDs generally have lower capacity than their larger desktop counterparts.
    Finally I did find a 320 ata disk at:
    http://www.drivesolutions.com/cgi/shop/s...
    One other thought, bigger, faster disks take more power which can generate more heat. Your system may have problems with these demands.
    Disks over 100GB in a laptop are generally overkill. I'd think about a new desktop with whatever disk size you need and use the current laptop to hold data you need for your current work. There are various programs that will sync data between the two systems or you can do it manually.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I want to upgrade my Sony Vaio VGN-FS630/W - which largest storage hard drives are compatible and what specifications should I search for while purchase?
From the age and specification of your Sony Vaio VGN-FS630W laptop you will need to buy a 2.5inch IDE internal disk drive if you wish to upgrade the existing drive.
The capacity you select will depend on how much money you want to spend as disk drive prices are much higher at present due to problems in the countries making these in the Far East due to flooding.
The machine should have come with an 80GB drive so you should be able to upgrade to a 320GB IDE drive with no problem - higher capacity IDE drives may be harder to find as the majority of drives today are SATA technology.
The procedure to replace the hard drive is described with graphics in a document provided by Sony Support.
You will also need software to help you migrate your existing operating system, programs and data from the old drive to the new drive unless you intend to perform a clean install of a new version of Windows.
There are a number of commercial or free utilities that can help you do the migration - Acronis True Image (commercial) is very good and effective but has to be bought - alternatively, Easeus Todo Backup is a free utility that can do the same. Paragon Software also offer several free utilities that can help you backup your existing drive and restore the backup on to your new drive - Paragon Backup & Recovery 2012 Free is one of these.
Dec 24, 2011 | Sony VAIO VGN-FS630/W Notebook
That model laptop will take anything up to 500GB and yes you can upgrade now or whenever you want.
Regards.
Aug 07, 2010 | Sony VAIO VGN-FS630/W Notebook
How to install memory VGN-FS630/w
Computer is shipped with 512MB, PC-2700, 333MHz DDR (256MB x 2) RAM and Expandable up to 1GB max.
You can refer the page # 145 in the VAIO User Guide to install the RAM in the Computer.
http://www.docs.sony.com/release/VGNFS600-A790.pdf
Apr 15, 2010 | Sony VAIO VGN-FS630/W Notebook
Hello, I need all drivers for a laptop SONY VAIO VGN-FS630/W. Where to find them??? Thank you very much.
go to sony.com and follow the links to install specific drivers for your laptop, each manifacturer provides their own drivers for their laptops or pc`s.. good luck
Mar 07, 2010 | Sony VAIO VGN-FS630/W Notebook
Sony Vaio VGN FS630W, nothing shows on screen.
boot files are corrupt or missing....
try re-installing OS
Jan 09, 2010 | Sony VAIO VGN-FS630/W Notebook
Sony vaio vgn-fs630/w. the ethernet port and usb ports not workin
The best thing you can try is a Static discharge.
Please remove all the external devices. Unplug the power adaptor.Remove the battery. There should be no electricity connected.
Then press the power button and keep your finger on it for about 30 seconds to release any build up electricity.
Plug in the adaptor and battery again and see if there is still a problem.
Maybe is a good idea to get a surge protector in the future.
Regards,
Purito
Oct 17, 2009 | Sony VAIO VGN-FS630/W Notebook
Restoring my Sony Notebook to factory settings
Make new disks from the 60G HD before replacing it. If there is no restore partition then you will need to clone your old drive.
You need a HDD cloning software like Norton Ghost, a usb 2.5" drive enclosure.
Apr 08, 2009 | Sony VAIO VGN-S560P/B Notebook
Sony VAIO VGN-FS630/W Notebook Logo
122 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
