Question about DeLonghi Kitchen Ranges
Beta 90 ss power to touch control panel but no powe to lights or motor
  • 857 Answers
This problem seems to be some disconnection on the main board in the device. To fix this problem you will have to open it and check all the connections and wiering inside on the board and accordingly we can repair it.
If you know about it you can open it and check it out else i will suggest a local repair guy.
Posted on Aug 07, 2010
Find a Diagram for 1989 Lincoln Towncar 4 Door Fusebox
this is for the base model
FUSE PANEL IDENTIFICATION (1983-90 LINCOLN TOWN CAR) The fuse panel is located in the instrument panel to the left of the steering column. To expose fuse panel, remove lower steering column finish panel.
Fuse & Circuit Breaker Identification
· 1 - 15 Amp Stoplights, Hazard Warning Lights, Speed Control Module, Trailer Tow Relays, Cornering Light Relay (1983-89)
· 2 - 8.25 Amp (Circuit Breaker) Windshield Wiper/Washer
· 3 - Blank
· 4 - 15 Amp Taillights, Side Marker, License Light, Parking & Coach Lights, Cluster Illumination, Trailer Tow Relay
· 5 - 15 Amp Turn Signal & Back-Up Lights, Trailer Tow Relay, Cornering Light Relays, Heated Rear Window Relay, Rear Defrost (1988-90), A/C Clutch & ATC Module (1990), Load Leveling (1990)
· 6 - 20 Amp Heated Rear Window Control, Speed Control Module & Clock Display, Illuminated Entry Module, Power Window & Police Accy Relays, Fuel Filler Door Release (1983-87), A/C Clutch & Cornering Lights (1983-89), Deck Lid Release (1987-90), Tripminder
· 7 - 10 Amp Daytime Running Light Resistor (1990)
· 8 - 15 Amp Dome LP-Clock, Key Warning Chimes & Electric Mirrors, Courtesy & Visor Mirror Lights, Autolight & Illuminated Entry Modules, Tripminder, Electronic Radio Memory, Trunk & Underhood Lights
· 9 - 15/30 Amp Heater Blower (15 Amp), AC/ATC Blower (30 Amp)
· 10 - Blank
· 11 - 20 Amp Radio & Power Antenna, CB Radio
· 12 - 20 Amp Door Cigarette Lighters, Power Seats & Door Locks (30 Amp), Tailgate Power Window (1983-89)
· 13 - 5 Amp Illuminated Outside Thermometer, Instrument Panel Lights
· 14 - 20/25 Amp (Circuit Breaker) Flash-To-Pass, Sun Roof, Power Windows
· 15 - 10 Amp Taillights, Parking, Side Marker/Coach, License Lights
· 16 - 20 Amp Horn & Front Cigarette Lighter
· 17 - 15 Amp Electronic Cluster, Message Center
· 18 - 10 Amp Warning Indicator Lights, Throttle Solenoid Positioner, Low Fuel Module & Autolight System, Dual Timer Buzzer & Electronic Chimes, Electronic Message Center
Feb 11, 2015 | 1989 Lincoln Town Car
Hi I have a new plastic body twin tub washing machine and when using the spinner it will give small shocks, can you please give me a hint what is causing this problem?
It sounds like you have an issue with your power outlet. Get an outlet tester at the hardware store and make sure you don't have a miswire there, first. If that's good, then check the wires from the plug to the washer. Make sure they aren't frayed, or anything. Then, check the wiring harness on the washer.
Oct 24, 2014 | Washing Machines
No turn on
pow pow pow pow
check all 4
power circuit breaker at panel power cord power outlet on wall
power switch on unit
Jul 11, 2012 | Amcor KF 9000 BTU Silver Portable Air...
Parex beta 90 ss rangehood stopped working Lights on switches work but not the fans or lights
Unfortunately didnt do anything about this for years. Managed to take off the white box behind the front panel swithes. Opened this up and "hey presto" the circuit board is faulty. Wouldnt it be nice if De Longhi sent out another one free of charge as this is obviously faulty, looking at some of the same complaints that have been posted. Imagine all the people that dont use computer or internet. I soldered wire between the points and it worked straight away.
Jun 10, 2011 | Microwave Ovens
While watching it, it went POW and a flash of light behind it and now it's dead. Nothing else surged that was plugged in with it (cable box and amp) It's only 4 years old :-(
The power supply unit went bad...it happens, and its cheaper to get a new TV than to try to get that one repaired.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
No power to main oven or either oven light
check your main panel for 240volts and again at plug in on unit,unless you have some power i.e. 120volts, you need 240volts to operate oven, also check neutral on supply line into oven/lights,thats open nothing will operate
Aug 02, 2009 | Rangemaster Professional 90 SS (electric)...
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Changing time format
go to control panel > regional setting, at time tab, you can change time format from H:mm:ss to h:mm:ss tt
Jun 11, 2009 | HTC Touch Diamond Smartphone
Kitchen Ranges Logo
277 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
