Question about Maytag Refrigerators
1.ice maker stopped functioning this morning. Water pressure is good. Temp in freezer is good. Bracket in down position. Parts store states thermostat not available! 2. unable to unscrew old filter in attempt to change, if twist hard the bracket warps! Model # mfd2561hes
    President:
  • 1,099 Answers
HI,
Take off the back panel in the freezer. 1/4" screws. Use a nut driver or ratchet and socket with an extension.
2. Behind the frost is the evaporator and the defrost heaters. One heater in the middle and one at the bottom. They are glass tubes. If you can see the bottom heater that is great. If not use a hair dryer and defrost only the very bottom to expose the lower heater only.
3. Now in the refrigerator section at the top where the controls are, take off the long plastic piece to expose the timer. The timer should be on the right hand side and have a little circle that is slotted. Get a flat screwdriver and turn that timer slowly clockwise just until it clicks and the refrigerator turns off. This will put it into defrost.
4. Now look at that heater that you exposed and see if it glows and gets hot. If it does, then the timer is bad.
5. If the heater doesn't come on then go ahead and defrost the rest of the evaporator with the hair dryer. This will take a little while. Don't poke at the evaporator!!!
6. Once totally defrosted look at both heaters. They should look like clear glass and see a silver coil running thru them. If they look discolored at all then the heaters are bad. The heaters come as a complete assembly with the defrost thermostat which clips onto the evaporator.
7. If the heaters look ok the only way to know for sure if they are bad is to check continuity with a meter on the plug at the end of their wiring harness. If you can check that then you can splice in a new defrost thermostat to solve the problem. However the best thing to do is replace the heaters and defrost thermostat . It is easy to install.
Follow these steps and this will solve your problem.
Take care..
Posted on Aug 07, 2010
The ice maker on my side by side frigidaire refrigerator has stopped automatically making ice. This model has the through the door crushed or cube ice and water/light dispensers. I can lift the wire to...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 19, 2011 | Frigidaire Refrigerators
Hi, We emptied our ice bin yesterday to fill an ice chest and the ice maker hasn't worked since. The automatic shut off arm is stuck in the down position and the entire ice maker compartment is...
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
Leo Ponder
imufo2
Sep 11, 2011 | LG LFX25960ST Stainless Steel French Door...
Brand new refrigerator not making ice the stop lever is stuck in up position??
THE STOP LEVER HAS TO BE IN THE DOWN POSITION. iF ITS NEW YOU NEED
TO CALL THE PLACE WHERE YOU BOUGHT IT. OR YOU HAVE TO FORCE THE
LEVER TO THE DOWN . TAKE IT OUT AND REPLACE THE LEVER IN THE DOWN POSITION
iF NONE OF THESE WORK THEN YOU NEED TO REPLACE THE ICEMAKER.
NOTE: This
.I'm including my article on Refrigerator Repair for your help and convenience.;
Leo Ponder
imufo2
Aug 13, 2011 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice Maker is making ice but at an extremely slow pace. The Ice Maker has been in the "On" position for approximately 48 hours and the pan is only 1/4 full.
HI,CHECK FOR UNIT TEMP FACTORY SETTING,CHECK FOR CLEAND CONDENSER COILS ,GOOD WATER FILTER, AND FOR A GOOD WATER PRESSURE ...
Jul 05, 2011 | Frigidaire IM501 FRIGIDAIRE IM501 ICE...
STOPPED MAKING ICE ?
1.Check shut off arm fails to move due over stored ice cubes in the ice bucket. Remove ice cubes and make free shut off arm to move.
2. Check water pressure.If less pressure will cause for non making ice cubes.
3.Check freezer temp. Setting must be 5degree and less.
4.Check power to solenoid valve for water flowing is working. Locate your ice maker, remove the ice bucket. Pull the coveroff the end of the ice maker. Locate the holes "V" and "L". Take a paper clip(jump clip) and tape. Straight the clip and put tape in middle. Hold the tapedside and insert the clip into "V" and "L". This sends the power to water valve.If water goes into ice maker, water valve is good. If not mechanism of solenoid is dusty. Call repairman to clean and re fix it. Thanks.
Jan 29, 2011 | Refrigerators
I have the Whirlpool gd25dfxfw02 and my freezer stopped making ice. I tried to fudge around with the silver lever/handle and stuck it back in the hole, put the lever down and it still hasn't made any ice....
1.Check shut off arm struck due to stored ice in bucket are too much. Clear it.
2.Check water pressure is normal.
3.Check freezer temp. Must be 5 degree and less.
4.Check water hose to Ice Maker. No leak in hose.
Hope helpful?
Jan 28, 2011 | Refrigerators
My ice maker has stopped producing ice - I have a whrlpool fridge freezer
Causes are:
1. Check shut off arm- If it fails to move due to lot stored ice cubs, remove some quantity of ice cubs.
2. Check the water pressure. Due to lack of water, it may stopped producing ice.
3.Check freezer temp: must be around 5 degree.
4.Check water hose has no leak. due to scarcity of water, ice maker could stop making ice cubes.
5. If water valve defective ice cube could not be made. To check the valve please follow this step.
Locate your ice maker, remove the ice bucket. Pull the coveroff the end of the ice maker. Locate the holes "V" and "L". Take a paper clip(jump clip) and tape. Straight the clip and put tape in middle. Hold the tapedside and insert the clip into "V" and "L". This sends the power to watervalve.If water goes into ice maker, water valve is good.Hope, is it helpful?
Jan 27, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working
There is a tub that goes through the back of the freezer wall into the ice maker. Sometimes this tube will freeze shut and needs to be thawed out.
The water fill tube will freeze shut from low water pressure. Ether from a bad water valve or low pressure to the refrigerator itself.
Pull the refrigerator out and remove the tube from the back wall to check it.
Also note that,
Sounds like the thermistor is bad in the ice maker itself, and there are 3 more micro switches, and some other things in there too, just easier too replace ice maker than parts for it.
If it turns out to be the ice maker, look on the tag in the ref. side, which list the model number and serial number. look @ bottom of that tag, it will give you a model number for the ice maker kit you need.
Good luck and hope this helpout......
Jul 30, 2010 | LG LFX25971ST Bottom Freezer French Door...
Ice maker doesn't work
I have the same problem. I've had the freezer for 2 years & ice maker just stopped making ice this week. Freezer works O.K.
Jan 11, 2008 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerators Logo
43 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
