Question about Olympus FE-150 Digital Camera
I am on vacation--wanted to take pics and camera will not work--zoom is out--fresh batteries--help
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 07, 2010
I just bought a vivicam 5022. Without doing anything to the camera, I lost a few days worth of pictures on it. It has a 8G memory card in it from the beginining. Without using the built-in memory of the...
Are your pics on the internal memory or the memory card? With no card in the camera, can you bring up the internal memory? If not, then any pics on it are gone. Your best bet at this point would be to format the internal memory to completely erase anything on it and vow never to use it. Is there anything on the memory card? You may have to use a card reader to find out.
Had you done your homework on this camera before buying it, you would have found out that nobody likes it. It's cheap and totally unreliable. Takes horrible pics and doesn't even have an optical zoom....only a terrible digital zoom. Saving the once in a lifetime pics from a vacation requires a much better camera.
Oct 29, 2010 | Vivitar Cameras
Hi, my nikon cool pic 3200, zooms in automatic on
Hello
Thank you for using FixYa for your problem
Zoom has had a knock
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Nikon Coolpix 3200 Digital Camera
My trackball zoom on my camera is not working anymore?
The same problem with me, i do a hard reset and it is fixed, simple isnt it?
To do the hard reset, just remove the battery for 1-2 minutes and restart the phone. This will reset the camera firmware to its factory default.
Aug 25, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Batteries die within 1/2 hour & zoom does not work
Are your batteries good? There are special Lithium batteries that are designed for cameras.
Aug 14, 2009 | Canon PowerShot A590 IS Digital Camera
Zoom error
There is no easy fix, you?ll have either disassemble and get dirty, or take to an authorized repair person. This zoom error problem is usually caused due to dirt or dust in the zoom mechanism.
If you think you can handle disassembling the camera then grab a set of gentile screwdrivers and follow these instructions:
You will have to remove a few circuit boards in order to get to the zoom mechanism.
Jul 01, 2009 | Fuji FinePix S700 Digital Camera
Write protected only comes up when I want to take a movie. I have a Olympus D-535 zoom camera.
Hi guys, I had the "write protect" message on my Olimpus c-370 zoom for a while and I tried everything, including buy a new Xd card.  When the new card arrived I had the same problem, and I was giving up... then I tried the camera using "fresh charged" new batteries and it works!
Hope this can be useful.
Dec 02, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
Camera powers off after seconds
Make sure that batteries are fresh and battery compartment is clean.
Mar 16, 2008 | Samsung Digimax S500 Digital Camera
EXILIM EX-760
Try resetting the camera. If that doesn't work then it is a repair issue.
In picture taking mode press menu
go to setup
go up to reset
press right arrow
highlight reset
press set
If that doesn't work then send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Nov 20, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blury Display on FE140
It sounds like your lens's focus element is stuck. Given the events you describe it is possible that a grain of sand has worked its way into the focus motor's gearing and jammed it up. Normally the small motor moves the focus optic in and out to achieve proper focus, if its movement is limited or completely jammed you will experience blurry pictures. The camera will have to be disassembled and the sand cleaned out to restore normal function. There are repair providers you can find online who can work on your camera. David Millier Advance Camera Repair
Mar 20, 2007 | Olympus FE-140 Digital Camera
Olympus FE-150 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
