Question about Cell Phones
Which is the circuit where you have to get microonul? (my microphone was broken) I can help urgently?
  • 37 Answers
Buy a new mouth piece replacement. hope this helps
Posted on Aug 07, 2010
Wiring for atw-t52
The other is most likely a ground. However you should use a good magnifying glass and bright light to look for tale signs of the connection that is broken.
Jul 18, 2014 | Audio Technica Audio Players & Recorders
Radio won't key up
Microphone or output circuit problem are most likely---The 25 is a fairly trouble free radio.
The microphone is the most common issue--broken wires inside the plug connection or a broken wire in the cable up to the microphone head.
Dec 21, 2012 | Cobra 25 NW LTD Classic Purist Mobile CB...
Sound quality from microphone is fine then becomes crackly.
its because you have broken or short circuit the wires or the microphone output pin may be not inserted properly.
Feb 19, 2010 | Computers & Internet
Wiring URGENT
bring it to your local electronics store. they will solder it back togerther for you.
Aug 07, 2009 | Shure SM58 Professional Microphone
Microphone on the house phone
chances are that the wire for the microphone has broken from the circuit board. you will have to open the phone(probably by removing battery cover and a couple of screws and re solder the broken wire.its not really a difficult job,but you may lose any stored numbers if the battery is removed for too long. good luck
Jul 22, 2009 | Uniden Cordless Phone
The mic doesnt work ...it use to but all the sudden it quit doesnt even key up so i can hear it my talk back
First, try another mic on the radio to be sure it's the mic and not the radio causing the problem. If it's the mic, check the wiring circuits for a bad switch or broken wire. Simply...the TX circuit is closed and the RX is open when the key is squeezed. The RX circuit is closed and the TX circuit is open when the key is released. Use a simple ohm meter to check for resistance between the pins on the mic (after removal from the radio of course). Open circuit will read 1, closed circuit should be very close to zero. You'll probably find the TX circuit never closes when the key is squeezed. Could be a broken wire or faulty switch in the handset.
Also check...If the mic "keys up"...you see the meter move normally, but no voice...it's either a faulty mic element (the little round thing you talk into) or the audio circuit of the radio has a defective component which a good CB shop can replace.
Jun 14, 2009 | Astatic 636L Noise Canceling Microphone...
Cable conexion is broken
I removed the cable from microphone circuit board  and shortened cable by 20 cm. to eliminate damaged wires, stripped the individual wires and soldered the pins to the new wire ends and reassembled.  Used black heat shrink tubing  [10mm dia.] to reinforce cable end at mic to prevent future damage from careless handling.
Document wire colours to pins before disassembly
Red                   Audio L
White                 Audio R
Blue                   DC Power
Shield [ground]     Ground
Yellow                 Video
Dec 13, 2008 | LeadSinger Wireless HiFi Remote Duet Mic...
Stoves model number 059040404
try the simple things first. check continuity thro the grill element - likely the element is open circuit
Aug 22, 2008 | Ovens
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
