Question about Whirlpool Duet GHW9150P Front Load Washer
Frontload washer gives a f code right before spin cycle
    Genius:
  • 1,417 Answers
what this f code indicate mean an error that there have been an over flow of water from the drum over to the panel or the wire .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Posted on Aug 07, 2010
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
May 23, 2010 | Kenmore Washing Machines
Spinning to slow closes still wet
Hi, how are you?
I'm guessing you have a clogged pump and is preventing the machine to go into the final spin cycle. It's very common with these frontloaders.
You just need to take the bottom plate off (3 screws on the bottom) and open the coin trap and clean it out. It should be right in the front. Try that and let me know what happens.
Thanks!
Ned
Jun 01, 2009 | Kenmore HE2 Plus Front Load Washer
GE Frontloader - will spin @ beginning of cycle, but never again
Check the switch on the door where clothes are loaded. I may be failing intermittently.
May 23, 2009 | GE WSXH208A Front Load Washer
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Frigidaire Frontloader 417.39022890
Hi thanks for the question. I would look at the pump. remove bottom panel. pump on the right, remove hoses, clean out the pump. thanks the appliance doc
Oct 07, 2008 | Estate TAWS800JQ Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
