Question about Meade ETX-90 (48x90 mm)
Fork mount on side of R.A. slow-motion control is coming loose from base. This is not the side that contains the Dec. slow-motion control. There appear to be 3 plastic pegs protruding from the fork into the base. It appears that there must be some means of securing these inside the drive base. This is not visible by simply removing the metal base plate. It might be possible to see this area by removing the plastic plate on which the batteries and motor are mounted. It looks like there is just one hex nut in the middle that needs to be removed, but I am apprehensive that I might damage the motor drive. Thank you for your assistance. Leonard Ellis
  • 11,896 Answers
The drive motor will not be damaged as long as it is not being pried or pulled on. There should be a nut or a threaded cone to hold the pegs in place. It may be stripped or just need to be tightened.
Posted on Aug 07, 2010
I have water hammer on my new Peerless kitchen
Single lever faucets can turn off a water supply instantly. Try slowing down your handle motions when operating your faucet.
Water hammer can cause damage to your water supply system and attached equipment...namely...your water heater tank.
If your water piping is easily accessed....you can use pieces of carpet cut into 4 inch squares to isolate the pipe from the wood joists, then use a J hook or wire hook to secure the pipe and isolation material (carpet). If you have copper tubing be sure to use plastic coated J hooks or wire hooks. Good luck and always know how/where to turn your water off before working on your plumbing.
ps if the hammering becomes a continuous fluttering hammer when you slow your handle motion....you need to tighten your crown adjustment nut located under your handle....most new faucets come with a tool that has an Allen wrench on one side to tighten the handle hold down screw...and the opposite side will have a fork like tool that is specifically used to adjust the crown adjustment nut. The nut is usually white plastic and has two notches in the top that fit the fork like tool. Turn clockwise slightly...then test...repeat until fluttering hammer is gone.
Jun 30, 2014 | Delta Faucet Delta RP17453 Pull-Down...
08 K1200GT, vibration when you roll out of the throttle at speed, 17,000 mil.
Hi, William and the usual suspects are:
1. Wheels and/or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect/poorly tuned engine.
7. Internal engine problem/flywheels shift.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Engine Vibration BMW com
My K1200S woes the letter and the fixes Bikes com Excellence in Motion
http://www.carlsalter.com/download.asp?p=347
BMW Motorcycle Parts Fiche OEM BMW Motorcycle Parts online 1970 present BMW
http://www.bmw-motorrad.com/us/en/index.html?content=http://www.bmw-motorrad.com/us/en/services/manuals/manuals_main.html¬rack=1
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 04, 2012 | 2008 BMW K 1200 GT
I have an older meade LX2000 EMC 10
The main problems encountered with the mechanics of the telescope centre around the mechanical swarf, grease compound, the liberal use of grease and the quality of machining of the main DEC and RA gears.
1. Remove the motors from the telescope. Be careful when removing either motor as there is a compression spring between the motor mounting frame and the worm shaft assembly.
The RA motor is located under the telescope body, removing the 4 screws and 2 Allen bolts will allow the bottom cover to be removed, thereby allowing access the the 2 Allen bolts holding the motor in place. Unplug the motor from the main PCB before removal.
The DEC motor is in the the fork arm containing the clutch and fine DEC adjustment control. (Never to be used with power applied to the scope). Remove the 3 small Allen screws holding the plastic cover plate in place and the DEC clutch knob to allow access to the motor. Remove the RJ45 connector located inside the telescope fork arm. Then remove the motor by unscrewing the 2 Allen bolts holding the motor in place.
2. Remove all grease from the motor worms, especially around the RA motor's magnetic pulse detector and the permanent magnet built into the worm shaft.
3. Remove all grease from the main DEC and RA gears, making sure to clean into the gear teeth.
4. Lightly re-grease with a Molybdenum Disulphide based grease (Castrol MS3 is great for this application if you can get it)
5. Assemble in reverse order. But before doing so, carry out the electrical adjustment above then, (a) relocate the the RA and DEC control PCB's in the vertical plane thereby gaining access to their respective backlash Allen screws. Adjust for 20thou max clearance when in final position. Note:- the DEC adjustment screw has to be replaced for a longer unit complete with a thin bolthead as this adjustment has to be carried out with a spanner....there is no room for an Allen key adjustment here.
6. A drop of Loctite must be applied after adjustment.
7. The final part of the process is to run in the gearing. Apply 12 volts to the motor wires, either at their respective plugs or to the motor direct. Allow to run for 2 to 3 hours in each direction by reversing the battery polarity to bed the teeth engagement. Remember to release the clutches.
Dec 28, 2011 | Optics
Science tech 262 manual
Can't find a manual. This is a 76mm reflector on a Alt/AZ mount.
1. During the day, put in the 20mm eyepiece and point to a object around 100 yards away.
2. Focus on the object
3. Align the finder to the object in the eyepiece
4, Set up at night, give the scope time to reach outside temperature
5. Point scope with finder at the moon. (More than half full will be too bright)
6 Use the lowest power eyepiece (highest number) and focus on the moon.
7. You may now use higher power eyepieces to observe.
8. Pointing the scope usually involves loosing 2 knobs to move the scope in up/down and side to side motion. There may be slow motion controls to adjust the scope as objects in the sky move.
Nov 27, 2011 | Optics
I have never had a telecope before and have purchased the Celestron 114EQ modelr n 31042 Im looking for step by step instructions on how to use it
Do you have a manual?
This is a small reflector style telescope on an equatorial mount-- the mount must be POLAR ALIGNED in orderr to be used properly. Guess you did not know that when you bought an EQUATORIAL mount.
Read this:
http://www.astronomy.net/articles/4/polaralign.html
Once the scope is polar aligned place the eyepiece with the largest number written on it into the focuser. The moon should be your first target at night. the RA knob and the DEC knobs (slow motion controls) are used to keep the object centered in the eyepiece.
Download this free planetarium software --
www.stellarium.org
Aug 25, 2011 | Celestron PowerSeeker 114 EQ Telescope
The DEC Slow Motion Cable Inoperative in both directions
Have you tightened down the clutches? This is a simple mechanism that turns a small gear when you turn the knobs.
If the gears are broken you will need to buy a new mount from Celestron:
Here:
http://www.celestron.com/c3/page.php?PageID=37
www.telescopeman.org
www.telescopeman.us
www,telescopeman.info
Aug 17, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Change oil fork
There is a bit of directions on how to change the oil. I will give you a link to a site that has pictures with step-by-step directions that will work for any bike fork.
http://www.bluepoof.com/motorcycles/howto/svs_fork_oil/
If you have any more questions, feel free to ask..
Nov 25, 2009 | 2004 KTM EXC 200
Bolt holding dec drive motor on 16 loosens.
You have a LARGE Meade telescope. This should be an easy fix if you can disassemble the fork arm and get inside.
First I would contact Meade customer service to see if they have a manual that shows disassemble instructions. If not I would join the Yahoo LX200 forum and look for help there with an owner of the 16 inch model.
http://www.meade.com/support/index.html
Just search in Yahoo Groups for the LX200 forum.
On smaller scopes the DEC motor is held on by two spring loaded bolts, probably one has become loose?
Nov 04, 2009 | Meade LX200GPS Telescope
Right ascesion slow motion control knob loose, does not work
The RA knob has a setscrew that fixes it to the shaft. Just need to find the correct size and tighten.
Jul 06, 2008 | Meade LX200GPS Telescope
Meade ETX-90 (48x90 mm) Logo
46 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
