Question about Kenmore 15899 Built-in Dishwasher
What causes a film to be left on glasses after being washed in dishwasher?
    Novelist:
  • 175 Answers
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is toadd some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 02, 2011
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
I am getting a terrible white film left on all my glasses and dishes in my dishwasher. It just has started happening in my last 2-3 washes. What can I do so my dishwasher starts washing normal again?
Go to walmart and buy, a product called lemmeshine and use it from now on untill glass is clear then check your watersoftner its not work(sorry).
Feb 27, 2011 | Dishwashers
I am getting a lot of soap residue left on my clean dinnerware and glasses, like a dry soap residue. what can I do to fix that problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 12, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
New Kenmore 13743. Many of the glasses come out with a white film on them. Called the local Kenmore (Marshall at 1-800-469-4663) repairman on the advice of my salesperson. He said that he has frequent...
Have you tried cleaning a single glasses with vinegar. Take a glass, soak it in vinegar for a couple hours, wipe it dry and see if the film goes away. If it does you know vinegar will work to help. I use vinegar with every wash now cause the film builds up quickly. If the film doesn't go away then it is likely that the glasses are getting etched by a corrosive detergent.
Dec 17, 2010 | Kenmore 13743 Staimless Steel Built-in...
I have washed and rewashed my dishes with no soap and my glasses have a horrible white film and any of my plastics now have white film almost as if the soap is not rinsing off. I have resorted to hand...
heatman101
l'l
Sep 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishes have food residue washed onto them and water spots on all glasses regardless of the amount of detergentinse agent. The pump seems fine there is no water left in the machine after a cycle. any...
heatman101
Jun 28, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Residue left in glasses and a film on the dishes
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jun 09, 2010 | Maytag 24 in. MDBH940AW Built-in...
My electrolux icon dishwasher leaves food residue in the interior of glassware and mugs. It has etched and left milky scratching permanent texture to all glassware. I have replaced glassware change...
heatman101
Mar 10, 2010 | Electrolux EIFLW55HIW Front Load Washer...
There is a whitish film left on dishes/glasses/silverware after wash cycle is finished.
Are you using Jet Dri or another type of rinse agent? If not, that will become your main issue. These machines HAVE to have it, or they wont remove that film. Also, have you changed washing agent (soap) etc. You may be using a little to much. Other issues that can cause this are: bad drain or main pump unit, clogged drain hose, etc. Let me know if you need any other help or information.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kenmore 15899 Built-in Dishwasher Logo
101 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
