Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Our screen says video 1 with no picture - Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
  • 132 Answers
You need to set your input for the source coming in. For instance if you have a cable box and it is hooked up in the back of the TV. to video 1 then that's what you need to put your input on your remote to. If you have an antenna and it's hooked up to your antenna port then you need to set your input to tuner. If you have a DVD player and it's hooked to your component ports on the back of your TV. then you need to set your input to component 1 or 2 whichever one you have it plugged into and so on. I hope this helps.
Posted on Aug 07, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
This is usually an easy fix. Depending how your tv is connected. Most probably it is the input you are on, or not on. Get your Sony remote look for a SOURCE or INPUT button. Press it and go to each input, for example, HDMI-1 2, INPUT-1,2 VID-1.2.etc.. Also check to see if your cables in the back is loose or out. Hope this helps
Samsung tv ps50a656 sound no picture
My guess here is that you have the audio and the video on different inputs. Check your wiring and make sure that your video and audio are on the same inputs (ex. Video 1 is matched with Audio 1). With the many inputs that TVs now have it is easy to hook up the video to video 1 and get the audio on something like Aux.
Oct 22, 2012 | Televison & Video
How to get VLC to play MP4 digital video on projector? I get a still picture, but NO moving video. And this still picture is only fully on screen with the aspect of 1:1. The MP4 digital video was taken...
This sounds more like a problem with your projector than with VLC. VLC is just a player, if it works properly on the computer screen then it should work properly going through the computer using the projector as output.
Jul 06, 2011 | VideoLAN VLC
Kpr-46cx10 picture issues
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Televison & Video
Input 6 - HD Input - Green Screen. Audio Only. No picture.
I am having a similar problem with the inputs. I have a cable box plugged in to cable antenna, DVD to video 6 using HDMI, Mac computer plugged in to video 7 - using HDMI (TV does not recognize this) and then Nintendo Wii hooked up to Video 1. My problem is that Sony only realizes 2 additional components like the video 1 (wii) and DVD on video 6, it does not play the other components. I have to niw manually switch the cables to have them work...
Aug 04, 2009 | Sony KDS-R50XBR1 50" HDTV
DVD plays but nothing is displayed on screen.
1.make sure that the video input/output are plugged in.
2.make sure ur tv is programmed to vieo 1 2 3 etc.
May 07, 2008 | Delphi MV10015 Car DVD Player
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
No picture or sound
If the screen displays VIDEO 1 then the set is in video 1 mode, looking for a signal on the video 1 input jacks. Press the TV/VIDEO button on the remote (or the set itself if it has it) and cycle around to the input you are actually using.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Black screen- cannot view pictures, can hear sound
ok do one thing,connoet rca video pin in component socket.. so that you can see bblack n white picture.
Aug 06, 2007 | Philips DVD 622 DVD Player
Please, Help me fix my TV
It sound like you have abad picture tube. Iknow this is not the answer that you want to hear. Sony's have video blanking circuit built into the video processor(in the jungle IC) when the emission of all three gun fall out of an acceptaable range. the screen blinks and when you turn the screen control on the IHVT all you see is re-trace. Some times there is a current limiting resistor in series with on lead of the heater on the crt board. By changing this resistor from 2.2 ohm to >.1 ohm @1/2 watt you can sometimes increse the filament voltage to the point that the blanking stops. This is only a temporary cure not a fix. The picture tube is probably bad. Scrivitron
Jun 20, 2007 | Sony KV-20FS12 20" TV
Coaxel and composite jacks produce scrambled picture, componite ok.
Bad hyper board = repair by qualified tech, PCB not available...
Feb 11, 2007 | Toshiba 50HX81 50" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
