Question about Acer AM5641-B5560A Desktop PC & Monitor BUNDLE
NO VIDEO ON AM5641 - Acer AM5641-B5560A Desktop PC & Monitor BUNDLE
  • joecoolvette
    joecoolvette Aug 08, 2010
    No graphics?
    As in No Signal shown on the monitor?
    Indeed it could be a graphics 'engine' problem, in that the Integrated Graphics, (Nvidia GeForce7100 ), could be bad.
    Integrated Graphics is also known as OnBoard graphics.
    ON the motherBOARD.
    The GPU chip is soldered directly to the motherboard.
    [GPU = Graphics Processing unit
    http://en.wikipedia.org/wiki/GPU
    Nvidia GeForce 7100 integrated graphics GPU,
    http://en.wikipedia.org/wiki/GeForce_7_S...
    No Signal = No video signal
    The computer isn't sending a video signal to the monitor, or if it is, it isn't getting to the monitor.
    Do you have a Known to be Good monitor cable, to swap out with the existing one, OR, do you have another working computer to use THAT monitor cable on?
    The monitor seems to be working fine.
    Monitor cable checks out?
    The next logical step is to assume a bad GPU.
    However, experience has shown me that the next area to check, is the Power Supply.
    Bad Power Supply, weak voltage power rail.
    A bad Power Supply is one of the leading causes of computer failure.
    Most of the time due to the inside of the computer, as well as the inside of the Power Supply, has been neglected in cleaning.
    A can of compressed air for computers, used on a regular basis as needed, can prevent this.
    However, not to slam your Acer, but this manufacturer is known to install inferior low quality Power Supply's.
    The Power Supply in your Acer is of a design used in many personal computers.
    An SMPS
    Switched-Mode Power Supply.
    http://en.wikipedia.org/wiki/Switched-mo...
    Left-click on the photo to the upper right.
    This will enlarge the photo.
    There are two cooling components for an SMPS.
    1) The Fan
    2) Internal Heatsink's used inside.
    [Heatsink:
    Basic construction of a Heatsink is a flat plate of metal, that has tall, thin fins protruding from it.
    The plate of metal absorbs heat from whatever object, it is placed against.
    the tall, thin fins radiate the heat away.
    When a fan is used in conjunction with a Heatsink, the air flow from the fan helps carry the heat away from the fins ]
    When these two cooling components are coated with a layer of dust, dirt, etc., the cooling capacity drops tremendously.
    Heat = Wasted Energy
    The Power Supply tries to keep up with the call for power, but eventually cannot due to heat, and wasted energy, and components inside fail.
    The Power Supply fails.
    There are three major power rails for the Power Supply you have.
    A) The 3.3 Volt power rail
    B) The 5 Volt power rail
    C) The 12 Volt power rail
    (Termed power rail, because each voltage comes from one single source inside the Power Supply.
    There are power cables which come from the Power Supply, and carry Voltages.
    Orange insulated wires carry 3.3 Volts
    Red wires carry 5 Volts
    Yellow wires carry 12 Volts.
    All these power wires start at one power rail 'point', inside the Power Supply.
    http://www.hardwaresecrets.com/article/1...
    A) ALL of the LED lights for your computer use less than 1 Watt of power.
    B) EACH fan uses 2 to 3 Watts
    C) A typical Processor can use from 51 to 125 Watts. Depends on what Processor it is.
    Acer Aspire AM5641?
    Supposed to come with an Intel Pentium Dual Core E2200.
    This Processor can use up to 65 Watts,
    http://en.wikipedia.org/wiki/List_of_Int...
    Point?
    You could have LED lights lit, fans spinning, (Or spin a few times then stop), and it may even sound like the Platters inside the Harddrive are spinning, but you may not have enough power to turn the Processor on.
    No Processor operating, No computer.
    No computer, No video Signal to the monitor.
    Test the Power Supply, or use a Known to be Good, Compatible power supply for a test unit.
    [Compatible:
    1) Has the correct power cables needed
    2) Has the correct amount of power cables
    3) Is the correct form factor (Size and shape of power supply case, essentially for this explanation)
    4) Has enough Wattage ]
  • Acer Master
  • 5,660 Answers
No graphics? As in No Signal shown on the monitor?
Integrated Graphics is also known as OnBoard graphics. ON the motherBOARD.
[GPU = Graphics Processing Unit
http://en.wikipedia.org/wiki/GeForce_7_Series#GeForce_7100_Series
No Signal = No video signal The computer isn't sending a video signal to the monitor, or if it is, it isn't getting to the monitor.
The monitor seems to be working fine. Monitor cable checks out? The next logical step is to assume a bad GPU.
The Power Supply in your Acer, is of a design used in many personal computers.
An SMPS Switched-Mode Power Supply.
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Left-click on the photo to the upper right. This will enlarge the photo.
1) The Fan
[Heatsink: Basic construction of a Heatsink is a flat plate of metal, that has tall, thin fins protruding from it.
The tall, thin fins radiate the heat away. When a fan is used in conjunction with a Heatsink, the air flow from the fan helps carry the heat away from the fins ]
http://www.hardwaresecrets.com/article/181
Acer Aspire AM5641? Supposed to come with an Intel Pentium Dual Core E2200.
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_Dual-Core_microprocessors#.22Allendale.22.2C_.22Conroe.22_.2865_nm.29
Point?
[Compatible:
(Just love it when I post a Solution as a Clarification!)
Posted on Aug 08, 2010
    Champion:
  • 219 Answers
Sounds like your on board graphics are gone. since you have a PCI-e card slot you can buy a PCI-e graphics card and install it. that should do the trick.
Posted on Aug 07, 2010
What type slot is it for video card
You have a PCI-E slot. It may be 8x or 16x but they are all backwards compatible. The other consideration for a video card is physical space in that case and your power supply. What video card were you looking at buying?
May 05, 2012 | Acer Aspire AM5641-U5520A PC Desktop
Brand and model of acer aspier am5641-b5560
If I understood you well, the XP OS installed on WD IDE HDD belongs to another computer, in this case you cannot simply install it on your Acer computer and expect it to boot without problems because the hardware is different. What you can do in this case is a fresh Windows installation.
Feb 20, 2012 | Acer AM5641-B5560A Desktop PC & Monitor...
No video no bios no beep
Either the power source or the motherboard have died. Take out the power source and test it by measuring its voltages. If it's OK then the motherboard has died.
Jun 17, 2011 | Acer AM5641-B5560A Desktop PC & Monitor...
MY pc WON'T boot up. I have a black screen.
try to check your video card. maybe it has a problem. if you reboot and you hear a beeping sound, your video card and/or your memory card is corroded. you can solve this by using an eraser to clean up the pins of your memory/video card from corrosion.
Nov 01, 2010 | Acer Aspire AM5641-U5520A PC Desktop
My Acer Aspire AM5641 had the blue screen pop up one day and say that there was a hardware problem and Windows was forcing a shut down. Couldn't get it back up...just no signal to monitor. Checked...
your video has failed . on this unit I work on this exact unit every day. the video is what we call integrated and there is a big problem with this there is no video card it is integrated on the mother board . the problem is the motherboard is almost impossible to find. my company services the whole united states and if your unit brakes and you have a secondary warranty i am the first line of contact . and the motherboard for this unit I can rarely fin . if it helps the part number is mb.sam09.001
May 13, 2010 | Acer Aspire AM5641-U5520A PC Desktop
Acer AM5641-U5520A will not
If you removed the memory modules and there is no change then I would start disconnecting one device at a time to see if that is causing the problem. Start by disconnecting the cd/dvd rom and then try booting the computer. Then try disconnecting any floppy drives or pci cards(except for video card). If it has a pci/agp video card then you will need to remove it and test it in another computer or test a working one in the problem computer. If it has built-in video then you will need to test a working video card in the problem computer. It could also be an issue with the power supply so remove it and test it in another computer or swap it out with a known working power supply. Also check the mother board screws that hold the board to the chassi are tight(the board uses them as a ground). Blow any dust out of the case and verify that there are no loose connectors. Also verify that the monitor is not the problem by testing it with another computer. Usually when a CPU is defective the computer will not respond to anything and will act "dead" so it does not sound like the CPU. If everything else checks out then it could be a bad motherboard.
Dec 28, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Can I add an internal graphics card to my Acer computer? AM5641-B5540A E2200?
yeap..
look for pci express graphics card (dedicated)..
better to have 'sli cross-firing'..
seek supervision of ur system admin/vendor....
Nov 10, 2009 | Intel Motherboard
Intalling dvd drive on aver am5641
there are two different kind of connectors for drive compoonents such as dvd drives: ide and sata. most computers have both nowadays, though.
Jan 22, 2009 | Acer AM5641-B5660A Desktop PC & Monitor...
Acer AM5641 Desk-top PC
when u power up the computer u heared any beep check then num lock if u abkle to num lock on and off your cpu is ok.then tv to cpu connection we have to check.
also press F8 key when u power the cpu then go to enable vga mode.
then change resolution to 800*600 or 1024 *768
Nov 24, 2008 | Acer AM5641-B5560A Desktop PC & Monitor...
Acer AM5641-B5560A Desktop PC & Monitor BUNDLE Logo
289 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
