Question about GPS
I have a Nuvi 255. I used to be able to use the device while it was plugged into the car charger. since I've updated the maps, I cannot. When I plug the device into the charger, i get an icon on the device (connected to a computer) and I understand this is the mass storage mode. How do i get back to being able to use the device while riding and plugged into the charger?
  • 1,514 Answers
This is a common problem in the garmin 200 series satnavs. It is caused by wear on the mini usb socket on the back of the satnav where the power cord plugs in. The plug appears to be fully pushed in but it's not. Push it in further and the problem will be solved.
Posted on Aug 08, 2010
Need map updates for a nuvi 255 looked on garmin site, but model not listed
You need to have your satnav registered to update it. You can find details of how to register and update it at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Apr 22, 2011 | Garmin Nuvi 255 Car GPS Receiver
Battery power was low on my nuvi 255.plugged into the garmin wall charger.now nothing works.wont power up at all.plugged into the car charger and still nothing..whats happened ?
The 2xx series had a batch with bad batteries and they are replacing them even out of warranty , try your serial number on https://my.garmin.com/rma/recallLanding.faces. See if it is eligible for repair, if not the unit is probably pooched.
Hope this helps!
Dec 09, 2010 | Garmin Nuvi 255 GPS Receiver
I've had two Garmin Nuvi 255 and have had problems with the car charger after a short period with both. I cannot charge my garmin while in a vehicle. Is this a common problem?.
you probably have a blown fuse in the charger plug..... Unscrew the silver tip end of plug CAREFULLY its spring loaded check fuse and replace with 3A fuse
Nov 22, 2010 | Garmin nuvi 255W GPS Receiver
I just updated my maps on my garmin nuvi 255. now when i plug the charger in I cannot use the device while it's charging, i get the competer connect icon only. works fine if I disconnect it from a charger
This is a common problem with the 200 series garmin satnavs. It's caused by the mini usb plug of the power cord not being pushed fully into the back of the satnav. Because of the way it's designed it feels like it is fully in but it's not. Push it in further and the problem will be solved.
Aug 07, 2010 | GPS
Nuvi 350 will not run on DC charger
Make sure your DC & AC charger is a OEM charger.
There is a good chance that there is a bad connection on the mini-USB port.
What happens when you plug the unit into the cradle and NOT use the mini-USB jack?
http://www.sharc.net/gps_charger_repair.htm
- Jim
SHARCNET-USA
Apr 19, 2010 | Garmin nuvi 350 GPS Receiver
My Garmin nuvi 205 keeps saying it is connected to the computer when it is plugged into my car charger. It worked great until the original charger broke and I had to buy a new one. Now this charger...
When your Garmin Nuvi 205 stops working or behaves strangely, there are two steps you can take yourself to try and get it going again:
  1. Perform a Hard Reset,
  2. Run WebUpdater to reinstall that firmware.
I hope that helps.
Mar 06, 2010 | Garmin nuvi 205 GPS Receiver
How do we update our garmin nuvi 255
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can get that FREE at Garmin here:
To download the latest unit software visit Garmin website: www.garmin.com/webupdater
First you have to set up an account at Garmin using the serial number on your GPS. Once you do that you can download firmware update for free.
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
By the way, the correct Garmin approved power OR download cables are a must!!
Does this help? Let us know. Thanks.
Jul 14, 2009 | Garmin Nuvi 255 Car GPS Receiver
I just purchased a Garmin nuvi 255, and the maps are inaccurate.
Just go to http://www.garmin.com There will be a registeration link. Yes I think that you will get a free mapupdate with your registeration at least they used to do that. You will need your unit serial number and model.
Apr 07, 2009 | Garmin Nuvi 255 GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Don't Want to Buy the Updated Maps (nuvi 200W)
If the PC icon comes up while using the car charger, then there is a problem with your charger or mini-USB port on your Nuvi. Many after market chargers are not wired the same, causing the PC icon to show up on the screen. In this mode, your Nuvi will not charge nor can you use your Nuvi for navigation.
You can use your Nuvi with old maps. No one says you have to update. You'll just get an occasional reminder that your maps are outdated.
- Jim
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
GPS Logo
103 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
