Question about Refrigerators
Admiral fridge not working after power went out several times last night due to storms. Freezer and bottom both no cooling
  • 10,515 Answers
Is it running?
Do you hear any buzzing / humming noise?
Thanks!!
Posted on Aug 07, 2010
  • 4 more comments
  • txanna Aug 07, 2010
    No I dont hear anything. Thought I would ask before pulling out to see if there is a reset. Worked fine before storms. Don't know if hasn't worked since last night or if went out between then and this afternoon
  • taran_2005
    taran_2005 Aug 07, 2010
    Thanks for your response!!
    Unfortunately, there is no reset button. The only way to get it reset is
    to unplug the cord for few minutes,say 30 minutes and then plug it in
    back. This would reset the microprocessor installed in the refrigerator.
    I wanted to have one more clarification.
    You mentioned that you do not hear any buzzing or humming noise. This
    information helps me a lot. However, you never mention - Other than
    cooling problem, do you see any other issue? Like no lights or dead
    refrigerator?
    Thanks!!
    well the light hasn't worked for about four or five months. I don't know what dead refridgerator means.
  • taran_2005
    Dead refrigerator refers that - There is no power entering the refrigerator. Refrigerator is not working at all.Fans are not running, no noise, no lights ----You mentioned only cooling . So wanted to get a clarification whether you could hear fan running or compressor running ?
    Thanks!!
    mmm I don't hear anything at all. The light went out months ago and when replaced the blub, the light still didn't work. However the freezer and the bottom still cooled just fine. Since thunder storms last night and the power going on and off about 3 times I haven't paid attention to it until this afternoon. I noticed soggy chicken nuggets in door and the ice less hard as normal.
    checked breaker and switched it a couple of times to make sure breaker was actually flipped to work.
    Then got on here.
  • taran_2005
    There could be many reasons. However, as the situation becomes worse after the storm, i would start by making sure that there is nothing wrong with either compressor or compressor relay. These are more prone to damage due to storm and is mainly responsible for no or less cooling.
    If you have experience in repairing appliances, could take all
    precautions necessary and use multimeter - You could do a continuity
    check on compressor motor and all combination's. An infinity value on
    multimeter would confirm bad compressor.
    On the side of the compressor you will see a box
    (maybe a cover) remove the cover if it has one and then remove the wire
    harness. next you will see the relay with the capacitor mounted to it.
    give the relay a tug and pull it off the side of the compressor. once
    you have it off pull the capacitor off and then give the relay a shake.
    If it rattles the relay is bad. if the relay does not rattle the
    compressor is bad and you will need to call a service guy to replace the
    compressor.
    Other option would be - Go to a local repair shop
    and get an overload and relay ( cost around $50 ).Replace it. If the
    problem still persists, then it is faulty compressor.
    Compressor's usually have 5 years warranty on it.
    Let me know the update so that we could proceed.
    Good Luck!!
    Thanks!!
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 11, 2012 | Refrigerators
Fan in freezer is making a real bad sound...... griding like it may be struggling to to stay running
This can be caused by frost accumulation on or aroundthe freezer fan Icing . And due to this no cooling will be in fridge compartment.
Unplug power and . defrost it. And after some times, switch on fridge.
This is due to auto defrost switch malfunction. keep temp setting at 5 degree and check auto defrost (if your fridge having that option) is working. If not you have to replace PCB. Thanks.
Jan 28, 2011 | Maytag Admiral Top-Freezer Refrigerator
I have a black admiral fridge( freezer on top, not side by side) the vents on bottom of freezer froze with ice and fridge stopped working completly
the evaporator coil or freezer coil need for flushing due to clogging on vents have a presence of oil need for reprocesses and charging of refrigerant after refrocessing.
Jan 22, 2011 | Admiral Refrigerators
Viking Refrigerator stopped cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 12, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
