I just got a WTV1903 TV from a friend. I have cable but the TV seems to only receive up to Chnnel 22. Is there a way to get more channels?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
You should have an auto programming selection on your TV. In the setup menu. But Does your cable have a set top box? If so Run cable line into STB and out to the input of your tv and if you use a coaxial cable you should be able to put your tv in CH 3, and use your stb remote to change channels. Hope this helps
Posted on Aug 07, 2010
Screen says no signal . How do I connect cable?
Connect an antenna, cable box or satellite receiver to the RF Input on the rear. Set the input to Air, or Cable, and run a channel scan for Digital Channels if using an Antenna.
Sep 27, 2013 | AOC L22W898 22 in. LCD TV
I only get channels 2 through 22, 23 on up - nothing
this is not a problem from remote control. You must adjut the TV program go to the MENu, run the scanner, for add the program TV.Try to reach you supplier TV cable for explain then, if there are not problem witht the receiver box.
however if you need to reset the code program go for free download:
www.fitness.manualsonline.com or www .remotecodelist.com
sincerely. God bless you
May 07, 2012 | Televison & Video
TV is not responding, turns on and off and does not show picture nor sound, does not move from channel 22-2
Couple of things.
  • Are you on an antenna or cable/sat box?
  • If you are on an antenna, the sub-channel of a local DTV station (22-2) was the only thing the digital receiver was able to pickup on the initial scan of channels.
  • If you are on an antenna, rescan for available channels.
  • If you are on a cable/sat box, and scanned for channels you probably picked up a like channel that is in the same bandwidth as 22-2. Probably not even a channel.
  • If you have a cable or satellite box, hook it up to one of the VIDEO channels using either a Composite AV cable (Yellow/Red/White) or a Component A/V Cable (RED/GREEN/BLUE with RED/WHITE for audio. If you are lucky enough to have HDMI for your source, use that.
  • Going forward, all of your changing channels will be from the SOURCE.
Mar 13, 2011 | Sanyo DP50747 50 in. Plasma TV
I get channel until #13 how does i get the other chnnel
TV's of this era have two modes that the tuner can work in. One is the AIR mode and the other is CABLE. In the air mode the tuner picks up only "off air" frequencies,... and up to channel 13 they happen to be the same as cable channels 2 thru 13. If you are using cable you will need to go into your on screen menu and find where to change the tuner from "air" to "cable" to get channels above 13. Older sets had a switch on the front and sometimes the back to select the tuner mode.
Aug 14, 2010 | Curtis CM19033S 19" TV
I can not seem to receive digital tv is there something i need to do
make sure that you have a good connection with the leads, plug in the cable and turn on your tv select dtv and it should say search for channels and then follow the prompts, if you are running the cable through a booster make sure that there is power on
Apr 17, 2010 | Samsung LN22A450 22 in. LCD HDTV
Dish dvr 625 can't get dvd/vcr player to work with tv2..
if you have the coax hooked to the VCR in you will need to change the VCR channel to 22 and leave the TV itself tuned to 3 or 4.. I recommend setting the vcr to 60 or 73 to see if you can get reception on there as that is usually the two channels that TV2 is modulated on. You can check the modulation by going to TV1 and pressing menu-6-1-5 on the TV1 remote. Thanks for using Fix Ya. If I can be of further assistance please let me know.
Jan 28, 2009 | DISH Network DVR-625 DTV Receiver /...
Tv wont get cable channels
Go To Menu And Select Setup Then Click Cable ? Also There May Be An Option For It To Search For The Channels Your Receiving.
Hope This Helps
Jan 05, 2009 | Samsung LN22A451C 22 in. LCD TV
CATV access
you need to hit the input button on your remote to CATV and u will get the cable channels
Jul 16, 2008 | Emerson TC1351 13" TV
Won't tune in all channels
Do you mean the channels from the internal tuner which would be channels 22 to 68, or do you mean satelite channels, as I do not know whether this set has a built in satelite receiver? Satelite broadcasters are often changing frequencies or satelites.- Programs come and go!
Oct 20, 2006 | RCA F27440 27" TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
